Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Error # 3802 - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My printer says "carrage jam" but there is nothing in the way of it! im am fureus, if this carries on, i will except for YOU to pay for a new one, and i would NEED to speak to the oners of kodak amidatly.
Posted on Feb 03, 2012
  • 475 Answers
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
If the error continues:
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Posted on Nov 12, 2010
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Error code 3802
  1. Upgrade your printer firmware to the latest version
  2. If your printer firmware is already up-to-date:
  3. If the error continues:
  4. If the error continues,
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Jan 19, 2014 | Kodak Office Equipment & Supplies
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Jan 20, 2012 | Office Equipment & Supplies
Printer will not clear the Error 3802 , what do I do?
Hello and Welcome to FixYa!
Error 3802 generally occurs in the Kodak Inkjet Printers.
To solve this error Turn the printer off and then turn on, this problem is solved by doing this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If you are still facing this then do it again almost five times & if still your problem is not solved and you still get error code 3802 then probably your KODAK EASY SHARE 5500 All-In-One Ink Jet Printer is in need of servicing by a service professional.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you and Keep using FixYa!
Aug 17, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
What is error code 3802 on an ESP 5 kodak printer?
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the printhead .If the problem still there then do it again almost five times & if the problem still there then final option contact to kodak support
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 26, 2011 | Kodak ESP 5 Printer
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Error code 3802
You give scant information for your comment - you don't really ask a question - so I am flying in the dark so to say.
Here is what I did find and I hope you fine it applicable and useful. http://www.fixya.com/support/t4349159-printer_shows_error_code_3802
As I said you dont give much info - like make and model of printer ...
Mar 19, 2010 | Office Equipment & Supplies
What is error code 3802?
"Printhead failure" - #3802 Solution (from Kodak website):
Feb 16, 2010 | Kodak ESP 5 Printer
"Printhead Failure" (error code 3802)
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
  6. Close the printer access door.
If error condition continues, contact Kodak for printhead replacement.
Best of Luck
Nov 17, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error 3802
printer can not talk to printhead... power off. wait. power on
Sep 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
183 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
