Question about Goldstar MV-1502 Microwave Oven
Turntable not turning, element not heating, fuse? Where is it, how do you get to it, why did it blow?
  • reg3 Nov 12, 2010
    How do you get cover off?
  • Goldstar Master
  • 43,501 Answers
The fuse is inside the cover and the outside will need to be removed to get there...
It could blow from a power surge or from a faulty component inside... hard to tell...
Best thing to do is to check the components while the cover is off... this will take the right equipment to test with and some experience...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 12, 2010
  • 2,100 Answers
If you take the cover off, you will find a schematic sheet folded up on top of the oven some place, it usually has trouble shooting stuff in there, like the fuse, etc. I don't know if you will find a fuse or not, maybe, but what probably blew is a voltage rectifier, should be called a recti-frier. It is a little transistor looking thing that is held down with 2 screws, it looks like a blasting cap, They are fairly expensive to buy, radio shack has them, but it might not be the problem, just one of the troubleshooting things on the list. I did the same thing to mine, paid way to much for it, couldn't afford to fix it, took it apart, found that paper, found the fuse thing, found a microwave in the dump with the cover off it and that fuse thing was staring me in the face, I grabbed it, took it home, guess what? It worked. Couldn't believe it, but I will never buy another expensive microwave , I'll buy the $39 special and when it blows, it goes!
  • Ned  White
    Ned White Nov 12, 2010
    There are 4 screws on the back or the bottom, take them out, slide the cover off. Just like a computer. Check it out.
My sharp R-352DC Microwave won't heat, and turntable doesn't rotate. Please tell me the problem?
Maybe a bad fuse. If the transformer is bad that would blow the fuse. The magnetron unit may be causing it too.
Nov 17, 2016 | Sharp Microwave Ovens
My microwave turns on, turntable turns, just won't heat. the microwave is 6 years old. Is it wiser to bring in a repairman or just replace? there is a picture of the microwave by the timer window.
There are 2 fuses inside the cabinet. One is for the clock and turntable. The other is for the high voltage transformer and the microwave module. If this fuse is blown either the transformer is shorted or the module has failed to cause the fuse to blow. Parts and Labor can get close to the cost of a new one, so get an estimate so you can have information to make your decision
Nov 09, 2017 | Maytag MMV4205 Microwave Oven
Turntable is working but no heat
Heating element problem.Either element is cracked or its connections are loose.You will have to heck with meter, to confirm, whether its element or its shorted wire to the elements.---------Thanks.
Apr 21, 2011 | LG Microwave Ovens
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Jan 02, 2011 | Sharp Microwave Oven Microwave Oven
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
Microwave turns on but doesn't heat. Turntable does not rotate
The magnetron (the part that heats the food) is probably done, they tend to go out if the fuse didn't blow and it usually isn't worth fixing as the cost of the magnetron is almost what it would cost to buy a new microwave.
Sorry for the bad news.
Benjamin
Mar 25, 2010 | Sharp R-930AK Convection/Microwave Oven
Whirlpool 3hler5437jq1 dryer blows fuse
that would be a shorted or "bridged" heating element .. thats replaceable by a repairman or someone familiar with electrical things ..
here is where you can order parts and instructions for your dryer
http://3hler5437jq0.theappliancepartswarehouse.com/
here is where you can purchase a service manual if you need more information .. ($10) ...
http://www.manuals-in-pdf.com/index.php?main_page=advanced_search_result&keyword=3hler5437jq1&forward=plist
Nov 27, 2009 | Microwave Ovens
Power but no heat
If you have no power in the microwave, check to see if the outlet is good by plugging something else into it. If there is power, you may have blown the internal thermal fuse, or the door switch may be defective. Either of these will keep your microwave from working. The thermal fuse protects both you and the oven by blowing if there is too much power going through it. When a fuse blows, it means that the wire inside that conducts electricity has broken, usually because of an electrical overload. When it blows, you need to have a professional microwave repair person replace it. If this is not the problem, it may be that your door switch has become defective. If the door switch isn't working properly, it won't let the circuit complete to operate microwave components.
Feb 19, 2009 | CDA Microwave Ovens
Sharp Carousel Microwave Model R520-LK timer will run but carousel doesn't turn and food doesn't heat.
I also have the Sharp Carosoul oven, symptoms - fan runs, controls are fine but the turntable stopped turning and it did not heat. It was not the switches, fuse, but in fact a sagging door that misaligned with the door switches. The true cause was a warn top hinge. As a temporary fix, I adjusted the bottom hinge (3 screws underneath), straightened the door, and now it works again.
Dec 16, 2008 | Sharp Microwave Ovens
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar MV-1502 Microwave Oven Logo
60 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
