Question about Amana Heating & Cooling
My PTAC is blowing smoke that smells like burning plastic when in Heat mode. Any ideas?
3 Suggested Answers
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
  • 674 Answers
SOURCE: the air conditioner smells like burning plastic
The fan motor or some other electrical component. Either way I would quit using it until it gets fixed as an A/C unit is cheaper than a house.
Posted on May 03, 2010
I have a dura flame electric fireplace and I turned it one and it smells like something is burning. I tried to vacuum it and I turned it back one and it still smells like something is burning. it is a
when things are brand new that produce heat they will smell funny for awhile but give it a couple days and it will not if you see smoke then get excited and unplug.
Jan 28, 2015 | Duraflame L Electric Stove with Remote
Can calcium deposit on the heat element cause the unit to smoke and smell like an electrical fire? And how can. I fix this?
It could be.... It could also be something plastic that got onto the element that is melting and smoking. It could also be a connector to the control board that is loose and is over heating. This is more serious. Carefully check the heating element for some foreign plastic part that is pressing up against it. If there is nothing, then call a professional to make sure that it's not the controller that is overheating and in danger of catching fire.
Jul 27, 2014 | Frigidaire Dishwashers
When i start white smokes comes out why
mine does the same thing.. it is a sign that you are burning oil kiddo..either that or antifreeze is finding its way into the engine through a crack or bad gasket.. check for oil smell and moist soot at the tailpipe, or a sweet smell if antifreeze..now if its a steam like smoke..thats normal byproduct of the burning fuel and goes away once the exhaust pipes and muffler heat up enough to blow out all the condensate water...
Jan 30, 2013 | Cars & Trucks
My problem is simple to describe: The computer starts and runs fine,except for the smell...and the heat. The smell resembles burning plastic,and the heat output is noticeably higher. There's no smoke...
It more than likey seems to be your fan if the heat from your tower is noticeably higher and the smell.
If computer still under gaurantee you will be able to get it repaired for free from the manufacturers.
If not, take the tower cover off, and get a hoover and **** all dust particles from the system.
You may also need to invest into another fan, this should stop the smell and also the overheating
Hope this helps and please rate thanks.
Mar 26, 2011 | HP Pavilion s7320n (EP140AA) PC Desktop
Inside fans blowing smoke (burning plastic smell)
Smoke and smell of plastic indicates that there is a short circuit inside. It is the protective covering on the electric wires. Unplug the refrigerator from the wall and call the repair person.
Aug 24, 2010 | Turboair Refrigerators
Ac and heat smoke
the heater core has a hole in it leaking antifreeze in your heater box
Jun 08, 2010 | 1995 Volvo 850
Engine coolant mixing with oil in reserve tank. blowing white smoke out exhaust
The intake is leaking,if it is a plastic one,replace the whole intake,if it is metal,replace the gasket.
Jan 24, 2010 | 1999 Ford Windstar
The Maytag gas oven Model: MGR4452BDW and Serial:
Are you sure it's clean/ Does the smoke smell like wire burning or plastic? Is there a chance that there is some left over spill just burning off?
Jul 22, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Heating & Cooling Logo
99 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
