Question about Cretors Goldrush Popcorn Maker
Need a thermostat for a e.chols pop corn machine were do I find one
  • 55 Answers
Try calling the manufacturer at: (573) 734-2210
Posted on Nov 12, 2010
Don't have a manual need to know how to operate Do I add oil or butter in bottom with the corn if so how much?
the ratio for popping corn with oil is three parts corn to one part oil . So a 6 oz kettle you would use 6 oz of corn seed to 2 oz of oil. Don't use butter to pop, it will burn.
Apr 27, 2016 | Kitchen Appliances - Others
What is the corn and oil amount for treat time popcorn popper tpc 603
I am not fimiliar with that brand . the corn/oil ratio is 3 to 1 so if you add 1-1/2 cups (12oz.) of corn with 4 oz. of oil the popping cycle from the time you dump the corn and oil in to when you dump it shoul be around 3-1/2 min. if its much longer its too much so try 8 oz of corn and 2-1/2 oz. of oil. By you using this test or formula I am assuming the kettle thermostat is set correctly already.
Jan 22, 2016 | Kitchen Appliances - Others
Gold medal kettle heats up but not enough to pop corn
do you put a half a teaspoon of oil in first before the corn kernels
other than that have the unit checked by an electrical appliance shop for problem thermostat or heating element
Nov 15, 2015 | Gold Medal Kitchen Appliances - Others
Popcorn doesn't pop to full size. The problem is, the popcorn pops however the sise of the opoed corn is only one quater the sise it should be.
Not enough heat in the kettle to do the job. The corn will dry out and pop poorly when there is not enough heat. Either a thermostat adjustment or replacement or a bad element.
Feb 01, 2014 | Cretors Kitchen Appliances - Others
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
Our elementary school has this Gold Medal 2213 Antique *** 90 Popcorn Machine. We don't seem to have any manual for it now. We would like to use regular corn oil and kernels, versus the all-in-one bag...
Generally, you want 3 oz. of corn to one 1oz of oil. The amount of corn you can put in the kettle depends on the size of the kettle. So take the kettle size, (I think that machine is an 8 oz popper) and divide 8 by three to get 2.66 oz. (about a third of a cup) of oil needed. So you would use 1 cup of corn, and a third cup of oil.
Feb 23, 2011 | Gold Medal 2213 Antique Gay 90's Mega Pop...
I have a Star model 89, manufactured in about 1986. Its a 14 oz kettle, and everything works, however the kettle will not pop the corn. The kettle is hot to the touch from the outside, but will not pop...
Make sure your agitator arms are properly functioning. If the corn is not being properly stirred, it will not pop. Also, make sure you are using the correct type of popcorn oil.
Nov 04, 2010 | Star 39 JetStar Popcorn Maker
Half the Kernals spit out uncooked
It coud be 2 things. Either a low grade of popping corn, or old popping corn. Hot air poppers blow the same temperature, until you shut them off. Although the better grades of popping corn cost a good amount more, you don't throw half of it away. Once the popping corn container has been opened, you should use it up within about 3 months. The internal moisture content is what determines whether corn will pop or not. Too much or too little moisture will not allow the corn to pop.
Aug 23, 2009 | Toastess Hot-Air Corn Popper Popcorn Maker
Need instructions for Toastess cinema popper TCP-6L
1 tbsp veggie oil for 1/3c. corn
2 tbsp oil for 2/3c corn
3 tbsp oil for 1 cup corn
i use 2/3 c as the max because it completely fills the bowl if you use 1 cup be sure to do it in batches or the machine will over flow.
happy popping
Aug 30, 2008 | Toastess TCP-6L Popcorn Maker
Pop corn jamming in the kettle
this happens if you put took much in at a time
Jul 13, 2008 | Nostalgia Electrics CCP-509 Popcorn Maker
Cretors Goldrush Popcorn Maker Logo
63 people viewed this question
Top Cretors Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Cretors Kitchen Appliances - Other Expert? Answer questions, earn points and help others
