Question about Maytag Bravos 3.8 Cu. Ft. Washer
My maytag bravos is flashing dl-what does this mean
5 Suggested Answers
  • 50 Answers
SOURCE: i have a maytag bravos and i keep getting LF WHAT
(Washer is taking too long to fill)
Check the following:
Are the hot and cold faucets turned on?
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press POWER/CANCEL to clear display.
Hope this helps.........................
Posted on Jan 08, 2010
  • 56 Answers
SOURCE: Any problems with Maytag Bravos mvwB750w?
you would be better off with a front load. they (bravos) dont sell all that well and probably wont be around too long
Posted on Feb 07, 2010
SOURCE: maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Posted on Jan 03, 2011
  • 6277 Answers
SOURCE: what does UL mean on the display screen of a
Sorry but I do not have the list for your exact washer but I guess it is 'UnLevel' so try this, please. (it could be unlocked!)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 11, 2011
I have a maytag bravos quiet series 300 dryer with the error message f73. What does that mean?
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73
have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Sep 22, 2015 | Maytag Dryers
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer flashes f 51
You will need to replace the RPS sensor. There is a kit available that will update that washer to the current design. Here is the kit to order.
Nov 23, 2012 | Washing Machines
Code f2
That is a user interface failure code. You will have to contact Maytag to interpret exactly what that means. That could be displaying for any number of reasons.
May 06, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
What does code dl mean
The "dL" error code means that the door/lid can't lock. Check to make sure nothing is stopping the lid from closing and locking. If everything looks ok, then you either have a bad door lock or a bad control board.
Jan 10, 2012 | Maytag Bravos MTW6600T Top Load Washer
A dl is flashing on the display when I start it
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 03, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washing machine is a Maytag Bravo, My Manual is packed as were moving, I need to know what the error code LD is and how to clear it
Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Make a careful visual inspection of the hoses, and see if you notice anything under the main tub, that could be causing a blockage.
Jun 18, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravo quiet series 300: Stopped at spin:
John
Jan 15, 2010 | Maytag Washing Machines
Maytag bravo washing machine displays DL and will not wash? Is there something we can do or do we need a repairman?
Indicates lid is not locked Check for items caught in the lid keeping it from closing. Press Power/Cancel once to clear the code.......hope this helps......
Jan 07, 2010 | Bravo Computers & Internet
Maytag Bravos 3.8 Cu. Ft. Washer Logo
261 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
