Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
I have a wertheim 2550 carpet cleaner but when handle is squezzed it wont let the water out what can i do to fix it
  • 5 Answers
SOURCE: water wont spray out of bottom carpet cleaner but
First try putting in a little hot water in the water resevoir , let sit for about about 5 mins. then try it. if this doesn't work, flip the machine over and locate the spray jets on the bottom. You'll need a pin or something small enough to clean out the jets bye sticking pin or paperclip in it . Detegent left in the machine sometimes cloggs the jets.Empty water before you flip the machine over.
Posted on Dec 15, 2009
SmartAlec
  • 171 Answers
SOURCE: How do you open a wertheim 2000P vacuum cleaner?
SmartAlec from NelsonVacuums.com.au here. The ET2000 has a latch that is located at the very end of the machine lid (about 6 cm in front of where hose clips in. If you sit the machine up on its back end you should see the black lever that needs to be pushed in. Now I will also say that it is possible that you have actually been pushing this but the lid still wont open, this is because every now and again the whole latch moves itself out of alignment by about a milimetre. The easy fix for this is a gentle screw drive to assist the relesing of the catch, this needs to be gently pushed in at the same time as squeezing the latch (hand at top of latch screwdriver at base kind of toward the middle of machine). You should be able to get it open like this with only light pressure. Now of course if you need bags or filters please visit us at NelsonVacuums.com.au.
Kind regards Alec
Posted on Aug 02, 2010
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
  • 384 Answers
SOURCE: carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
Posted on Apr 05, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Oreck carpet cleaner wont **** up water
Your reservoir is full. Empty the water and it will work properly.
Feb 20, 2013 | Oreck XL Shield Power Scrubber Floor And...
Vaccuum cleaner with a broken hose
Is it just the corrugations of the hose broken? With most hose fittings there are two small oval shaped lugs on the side of the fitting. Grab a small screwdriver and gently (you may need a little force) push these in to ease the click ring out.
Once out, you'll find a type of screw cuff. Some hoses just unscrew, some are glued in (use boiling hot water to soften to separate).
Cut the broken piece of hose off, make sure the click ring is still on the hose in the right direction, reaffix the screw cuff, and replace the hose (with click ring) back into the hose fitting.
If it's actually the hose fitting broken, check with your local Wertheim retailer or repairer.
May 20, 2010 | Vacuums
Bissell carpet cleaner wont **** water out of carpet.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rw245
Apr 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Model # 8920 bissell steam cleaner wont **** up the water
heatman101 //
Dec 27, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
Jun 08, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
No water/to carpet
heatman101
fgn
Dec 14, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissle proheat carpet cleaner/vaccuum has become clogged with the cleaner solution. As a result the cleaner solution does not reach the carpet when in operation. I had this fixed before at a local...
Take apart the handle (a few screws) unclip the small clear hoses, use a pipe cleaner or small screwdriver to clear the hose from the crystalized cleaning solution that is blocking the hose. Put it back together and it will be like new. ALWAYS run plain water through your machine when you are done using it to rinse it out.
May 01, 2008 | Vacuums
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
805 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
