Question about Ionic Pro 901P2RIP04 Air Purifier
RED CLEAN LIGHT
CLEAN LIGHT WONT GO OFF
  • 3 more comments
  • cynthea Jul 22, 2008
    Problem: red clean light stays on, even though I have cleaned the unit. Tried to reset but the blue light would only stay on for a moment then the red clean light came on. I left it on, watching to see if it would shut down and so far ( 3 hours have passed and unit is still on) Makes me wonder if perhaps there is nothing wrong (except for the lights not working properly) the unit seems to be working as it should.
    Cynthia
  • Anonymous Mar 25, 2009
    Same problem
  • Brent Sugita Apr 08, 2009
    I am having the same issue on this. I tried cleaning the unit. After I reinstalled the blades and turned the unit on, the blue light turns momentarily on, then switches over the the orange cleaning light. I've cleaned the wire using the the lift lever also...
    If the orange cleaning light is on, is the unit still functioning?
  • MajesticMike Apr 10, 2009
    The problem is with the PCB (circuit board) in the top of
    the unit. I had this same problem, went out and bought another unit, swapped
    the old unit’s circuit board with the new unit’s circuit board and the problem
    followed that old units circuit board. When I put the new unit’s circuit board
    in the old unit it started working again and has worked find for months now.
    Now I have this new unit with the old + bad circuit board
    sitting doing nothing waiting for me to diagnose it further. I’m not sure where
    to start maybe capacitors or transistor checking?
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Bob
Posted on Dec 31, 2010
    Problem Solver:
  • 3 Answers
Attempt cleaning the contacts at the base of the blades (with the blade cartridge out, you'll see them) with an alcohol swab or pencil eraser. In the first case, make sure the alcohol has evaporated before putting the blade cart back in, and in the latter, sweep or vacuum up the eraser debris. May or may not work.
Posted on Feb 23, 2009
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Can I still use the air purifier if I put clean filters even if light is on red light wont go off
Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine.
Jun 13, 2014 | Ionic Pro 901P2RIP04 Air Purifier
Why does a red light on top of the ionic breeze GP S1750 blinks and does not blow the air
well i had the same problem at one time ..heres what to do... try turning it upside down and bang on the unit gently .not to break it and make sure you did not break the two strings behind the vents..
take out the bulb and clean the whole inside as best as you can..
and if that wont work unplug turn button to on pisitioin and then plug the unit inand hope for the best ... if all else fails go to amazon and replace the unit..hope that helps
Jun 11, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
The red clean light won't reset
When the red 'clean' light goes on and wont go off, that means you just wasted $100. Next time just send me the money.
Feb 06, 2010 | Ionic Pro 901P2RIP04 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
Ionic Pro 901P2RIP04 Air Purifier Logo
3,068 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
