Question about Coleman Heating & Cooling
I NEED A WIRING DIAGRAM FOR A SEQUENCER ON A COLEMAN 3500A816. NEED IT ASAP
tborn6
  • 700 Answers
SOURCE: Need wiring diagram
here would be the hook ups that are needed. at the air handler
r-red
g-green
c-common
w1/w2/aux-white (DEPENDS ON WHAT TYPE OF SYSTEM YOIU HAVE)
then these are what goes to the outside unit
y-ylw
o- org/or b-blue
c-white
r-red
personally contact me if yopu still have questions. thanks
Posted on Jan 12, 2009
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
SOURCE: LOGITECH QUIKCAM WIRING DIAGRAM HELPPPPPPP
  1. driver
Posted on Aug 02, 2008
CarlGehrke
  • 169 Answers
SOURCE: Hello I have a coleman
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Posted on Dec 03, 2008
TheMobilian
  • 8220 Answers
SOURCE: i need wiring diagram for an old coleman suncutter/whole house a/
yeller cool
red common
white heat
green fan
Posted on Jun 06, 2009
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Where can I get a schematic for a Coleman 3500A816 air handler?
With some units you must set thermostat to fan on to get the fan to run in heat mode.. or it could be a bad motor or fan relay . Generally in electric heat units one side of heater is always live then the sequencer turns heater on when thermo calls for heat.
Nov 19, 2014 | Coleman Heating & Cooling
Have Coleman mobile home unit electric furnace changed sequencer and limit switches strips stay on after cycle and also run with unit switched off
This is the one where you have to lay on your head to work on it, I assume? Has to either be a bad sequencer, or the thermostat/thermostat wiring. If all the strips stay on, something is miswired, or your thermostat is keeping them on.
Nov 05, 2013 | Heating & Cooling
I have a 1987 mobile home with a coleman electric furnace model 3400-812. I need a wiring diagram for the repairman to use to rewiring all the new parts. He has installed a new fan blower motor, new...
5cd0d9d4-9d59-458b-ae93-d14f7aa016ab.jpg728c66bc-7660-4666-bc17-bdfa1b3130ed.jpgded744e2-3c31-4bc2-aec3-aa2d40664be6.png
I mean this respectfully, if the technician cannot wire a unit without a wiring diagram , he is not competent to do the work.
It is really very simple, If you look at the power lines entering a building, ther are but 2 hot legs of 115 volts for 230 volts and a earth / ground, every wire we will ever see are these 2 hot legs or a combination of them.
Every circuit requires 2 sides/legs of power, a device and a switch, begin at L1 go through switch to load return to opposite side of power from where you began, very simple.
If you do not know this a wiring diagram will tell him nothing but how to blindly try to follow some diagram he has no grasp of the theory behind or he would see how simple his dilamna is.
Oct 19, 2013 | Coleman Heating & Cooling
Eb20b heater temp goes down from 120 degrees to 90. 240v at sequencer and both heating elements and limit switches, testing from ground to wiring on those. when i take cover off of fan motor enclosure...
Sounds like an airflow restriction. If you remove cover you are giving the fan all the possible air it can get, therefore it seems to run properly.
Jul 08, 2017 | Coleman Heating & Cooling
Need wiring diagram ,colman central electric furnace 3500a816
I have the diagram pasted to the cover over the sequencer. I only have a 5 megapixel camera, but I am willing to try and get a picture of it if it will help.
Nov 03, 2010 | Coleman Heating & Cooling
Need replacement part # and wiring diagram for Nordyne Intertherm E1EH O12HA sequencer
take it to a hvac supply house and they will match it up for you. The wiring diagram will be on the furnace
Oct 30, 2009 | Heating & Cooling
Heating & Cooling Logo
308 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
