Turn the printer around so that the back is facing you, and open the back panel. There should be two plastic tabs to push and release it. Open the panel and it gives you access to the rear rollers that push the paper through. You will be able to see any paper that is stuck there. Remove it, then push the "ok" or "enter" button on the front and the printer should continue normally.
Where can I buy HP 7310 all in one office jet printer heads?????
SOURCE: HP Officejet 6310 All in One - small paper being
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Testimonial: "This worked perfectly. Thank you."
