I have an H/P color inkjet 4-in-1. I can print from the computer, but when I try to copy or fax, the machine jams. I'm wondering if I need to clean the sliding bar or something similar?
  • Tricia Scerbo
    Tricia Scerbo May 11, 2010
    What is the model number of your HP? Also, where is the jam occurring?
    Scholar:
  • 152 Answers
To add to Bubbabear64's solution, remove the paper and fan it to be sure that the paper isn't sticking. Additionally, are you using quality paper? Some printers want you to supply them with the best paper.
Posted on Jun 18, 2008
  • 2,794 Answers
Usually that thing will jam in all modes or not at all.
Make sure it is pulling only one piece of paper at a time.
If the paper hasn't been used in awhile check the paper quaility for wrinkles or other blemishes.
Posted on Jun 17, 2008
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Black ink not working lexmark pro915
Check ink level, clean contacts on cartridge and machine.
Oct 10, 2013 | Lexmark Pro915 Wireless All-in-One Inkjet...
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
~enov8
Feb 16, 2009 | HP 640 Inkjet Fax Machine
My fax is jammed and not printing does sender get an OK?
IF your scanner is working then you can send faxes it will stored in the printer memory and then send the fax..
Good luck...
Nov 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Will not print black
The ph will be cleaned by pressing ink thru the system (tubes and ph). Do use only dye-ink for this procedure. The best way is to use original brother ink.
place a new cart into position and make sure that they are secured.
press menu then start bk copy then fortimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink and do some cleaning. afterwards press 7 then 6 then 3 then start bk copy. machine will do a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a test quality print by pressing ink etc.. If you cant see any bk the ph is defenetly clogged and cant be fixed anymore. It needs replacing.
Dec 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Color printing
if you have used generic ink the ph might be destroyed.
Nevertheless give it a try (use nearly FULL carts):
press menu then start bk copy then 4 times arrow up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh tubes and ph with new ink and do some cleaning cycles. when finished press 7 then 6 then 3 then start bk copy. machine will do a power cleaning. leave maintenance by pressing 9 then 9. Do run a quality test print by pressing ink etc. If you cant see any color blocks the ph has to be replaced by a new one.
Dec 12, 2007 | Brother MFC-5440CN All-In-One InkJet...
Printer and Making Copies does not work!
Will the machine run a paper path test?
This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
Nov 26, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
107 people viewed this question
jasbo
jasbo
