Question about Xerox Phaser 6130 Laser Printer
I need help with a xerox 6130? It prints color fine, but black is very light.
  • 1 more comment
  • plantero Nov 15, 2010
    Thank you for your suggestion. Unfortunately, it did not change the print quality. I am afraid this may not be a software issue. I tried changing the contrast and black density settings and it did not change the darkness of the text print at all. Keep in mind that this issue occurs even when test print pages are printed from the control panel. The printer seems to think that the grey level it is printing text is the equivalent of black. All other colors are normal. I did not see anything in the manual that could assist with this issue. Any other ideas I could follow up on?
    I have swapped out the black toner twice. It is registering at 100%. I have had the printer for only two years, and the overall print **** is very low. If it is then the imaging unit, do I just purchase one from Xerox and install myself?
    I apologize - I meant to type "print count". Need to do a better job of previewing my posts.......
    Guru:
  • 610 Answers
You can access the printer menu by going to Printers in Control Panel. Right Click on your printer icon and left click on properties. That should open up the printer properties window where you can configure your print settings.
Here's a manual for a guide.
http://www.office.xerox.com/latest/613EG-01.PDF
Posted on Nov 12, 2010
My Xerox phaser 6130 printer is progressively printing fainter and fainter colour prints
Go through troubleshooting by Googling the unit. Don't go switching stuff around before researching.
Nov 30, 2013 | Xerox Phaser Office Equipment & Supplies
Why is my xerox 6130 only partially printing
it is possible that the scanner lense for the laser has become dirty, normally if you remove the print cartridge (Tonerand drum assy) you can see a small strip of glass, this can collect toner and dust causing the lazer not to charge the drum and give you bad or light prints
hope this helps
Feb 08, 2011 | Xerox Phaser 6130 Laser Printer
My xerox Phaser 6130 is noisy and makes light copies. How do I lubricate it? Will this solve the problem?
The 6130 is not designed to be lubricated, but if you feel the need to lubricate gears, then use white lithium grease. I am not sure the nature of your noise. Loud rattling or repeating ticks could indicate damaged gears, and lubrication won't help that.
Often the Image Unit causes noise and bad print quality. Try replacing that first, PN 675K69244.
Whit
Nov 15, 2010 | Xerox 5665 Copier
My xerox phaser 6130 prints only in black
Check if the color cartrige is properly plugin in the printer
Dec 07, 2009 | Xerox Phaser 6130 Laser Printer
Xerox 6130, prints black very light. Replaced two
I think your Image Unit is going bad. Order this PN 675K69244...That should solve it.
Whit
Item, Inc.
Oct 23, 2009 | Xerox Phaser 6130 Laser Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Black printing is very dull but colors are bright in Phaser 6130
I have the same problem with a 6350 Phaser. Did you get it fixed?
Jun 11, 2009 | Xerox Phaser 6130 Laser Printer
My Xerox 6130 keeps printing vertical pink lines on pages
your color laser printer pink vertical line appear on the roller and film drum,
1) you need check the pink drum surface, it got damage if you find there is a different color vertival line on the drum surface, so you need change the pink drum.
2) check the pink drum cleaner (call brush to return the waste toner), it can not clean well sometimes, if the drum surface good.
Feb 06, 2009 | Xerox DocuColor 12 Printer
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Sep 20, 2008 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6130 Laser Printer Logo
399 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
