Question about Montgomery Ward (223600UP) Heater
How do i relight my standing wall heater light, where is it?
    Genius:
  • 1,015 Answers
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Posted on Nov 12, 2010
My water heater will heat up the water, once it comes to temp, the pilot light goes out.
depends on the year it was made , but if it was made after 2010 there is a high possibility it has electronic ignition, these models don't have a standing pilot and all signs of flame go away after it reaches temperature, I guess the best way is to see if it relights after using some of the hot water and it adds some cold water into itself , if its this type it will relight itself and burn to heat up cold water
Dec 14, 2016 | Water Water Heaters
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
2her is pilot light on remeha avantaplus boiler
? 7:54
How do i relight my water heater
turn gas knob to off, wait a minute, then turn knob to pilot. then press down on knob while lighting pilot, hold down at least 1 minute, then let the knob up slow. if it lights, then turn knob to run. if you can not light it after a few trys then the thermal coupling is bad and needs replaced. have a good day !
May 01, 2011 | Rinnai Orbis Vented Heater 15,000 BTU Wall...
Williams 5009662 pilot light went out, can't tell where to relight
you relight it ,,but it is better you are lyning down to see where to light it,,,but some have a red botton that you push to relight it ,,,like a bbq grill it makes a spark and when you turn the control knob on pilot to light it
Jan 14, 2011 | Williams (5009622) Ceramic Gas Wall...
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Montgomery Ward (223600UP) Heater Logo
458 people viewed this question
Top Montgomery Ward Heating & Cooling Experts
Paul Carew
Mack Baxter
Are you a Montgomery Ward Heating and Cooling Expert? Answer questions, earn points and help others
