Question about AT&T High Speed DSL Modem
I have new direct tv installation. now my dsl keeps dropping out. i unplug the direct tv box and everything is ok?
  • 823 Answers
It sounds like they have given you the base DSL service with the minimal speed. If they did, it won't be enough to run two things at one time on the same dsl line. Call AT&T and check your speed or service that was installed and ask if it is enough to run to computers on the same line at once.
Also make sure that there is no filter on your dsl line that goes to your computer.
Here is another tip; the longer the phone line from the wall to your computer, the slower the dsl service. Longer cords slow down your internet.
Posted on Nov 12, 2010
I have a problem with direct tv. It now says Channel not available (no signal).
The direct tv box is the problems and the causes.Unplug,replug the direct tv box about an hour later for the box to reboot and upgraded it software.The direct tv signal should be back.If still not getting a signal for channels,the direct tv box have problems.Call the direct tv customer service,exchange for a new direct tv box.Should solved ur problems.
Mar 19, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
HI my zyxel keeps dropping the line.In general its ok then for no reason it wil run 10 mins drop out then start again sometimes it will run a few days, logging into statistics the time counter has started...
MAKE SURE EVERYTHING THAT IS PLUGED INTO THE
PHONE JACKS HAS A DSL FILTER PLUGED INLINE. DO NOT FILTER THE ROUTER...IF THAT DOES NOT HELP THEN CALL YOUR LOCAL PHONE COMPANY TO INSTALL A WHOLE HOUSE FILTER IN THE BOX ON THE SIDE OF THE HOUSE....
Mar 07, 2010 | Computers & Internet
Hooking up my x-box 360 through Direct TV
Ok i had it installed today too....i already had it so i have experience with it....get a vcr....in th eback there should be some ports for AV cables hook that up and get one of those cords that look like the direct tv cords and put that in you VCR out to tv...and screw it in with your hands in your tv.....when you have your VCR on the direct tv wont show and if your direct tv is on when your xbox and VCR are on it still wont so turn off the VCR to get direct tv back again.....im 13 and i figured this out...hopefully this helps a bit
Sep 26, 2009 | Microsoft Xbox 360 Console
AT&T just gave me a new Motorola DSL box and I can't get my router to even find the internet which is active. I can only get the router install portion to go just to where it can't find the...
First of all using the Router Install Portion try to do a 'factory reset' or a 'reset to default'  - wait for a reboot to see if any change occur.
Next try to use the cable between your Moto Box and your LinkSys Box in a different port on the link sys. It may sound silly, but it can work very well sometimes.
Nick
Sep 03, 2009 | Linksys Wireless-G WRT54G Router
I have an AT&T Modem; having trouble with internet connectivity
It is OK to keep putting the UN and PW in. However you shouldn't have to. I suggest having a tech come to your home and have them do a signal test both at your jack and outside with your home unplugged from your service box. If there is a big difference in the numbers then you're simply loosing signal due to signal bleed inside. This is a simple fix. Have them isolate some wires in your jack and place a DSL filter outside. Then your DSL signal will go straight to your modem and not bounce all over your home. This will NOT affect your phone.
Dec 31, 2008 | AT&T High Speed DSL Modem
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Router "wireless G" will not
I had the same problem with a router of mine. I had it replaced and the new one works great.
Sep 05, 2008 | Belkin Computers & Internet
Power light just blinks
can you get a signal without box to tv
everythings going hd these days it could be they have it set for an hd
rf's pull there signal from the air and and filters to wear its supposed to go
hd is direct signals
9 times out of 10 the new box in not compatible with tv
or the guy who came in and installed the box did something to your tv and ran away
May 16, 2008 | Toshiba 32A43 32" TV
Phones Dead but DSL OK
A short inside the house should also disable the DSL service, but you can rule out this possibility by disconnecting the inside wiring from the outside wiring at the entrance box. If you still can't get a dial tone when you clip onto the incoming wires, then you need to contact your local phone company to have them find the problem and restore your phone service.
Good luck...and I hope this is helpfull!!
Jan 26, 2008 | Lands Phones
AT&T High Speed DSL Modem Logo
127 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
