Question about Frigidaire FRU17B2JW Refrigerator
How do i get the drain pan out without breaking it, it is a frigidaire all fridge fru17b2jw9
There is condensation under upright frigidaire freezer model number FFHI7F7HWE . also dripping water on the floor
There should be a drip pan under fridge to catch the condensation if pan is full it will cause water on floor or if drain line from defrost system could be plugged. Causing moisture to find alternative path.
Jul 25, 2017 | Frigidaire Refrigerators
Frigidaire electrolux refrigerator FRT18S6AW7
There will be a drain pan under your fridge that will collect the condensation fron the freezer defrost, and the heat from the compresser discharge line will evaporate the water. I would check to make sure the drain pan has not moved or the water drain line may have Allen out of the drain pan. All of this will be at the back of the fridge on the bottom, you may have to unscrew the back cardboard panel to get to it.
Sep 06, 2012 | Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
My frigidaire refrigerator is leaking from the bottom of the freezer compartment.
usually the most common problem is the drain tube is plugged. This tube runs from the bottom of he fzr thru the fridge compartment to the underside of the fidge to a drain pan. First try to blow air from the bottom of the line. Second ck where the drain enters the Fridge from the freezer this is a very common area for this problem. good luck
Aug 13, 2010 | Frigidaire Refrigerators
Do refrigerator drain has u trap
No they don't. Just one straight drain hose that goes to bottom back of fridge to the drip pan/evaporator pan
Dec 22, 2009 | Frigidaire GLRS264ZA Side by Side...
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Water dripping down on top shelf of refrigerator compartment.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 18, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Water on floor
is possible that the plastic tube that leeds in the pan is obstructed or in a wrong position, check if water goes in the pan just put some water trought from the inside hole in the fridge and check if it reach the pan, maybe the inclination of the fridge is not sufficient, ( it has to be inclined to the wall direction so the water slides on the back inside wall of the fridge. can also be poor insulation of the fridge, so the outside surfaces come wet because of the hight air temperature outside and the cold surfaces of the fridge, then the water slides down the floor...make sure about air ventilation around the fridge!...I hope it was useful!
Jan 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Drain pan
If u have 2 people u can lean the fridge back and the drain pan unscrews from the fridge from the bottom even though it says "non-removable
Oct 24, 2008 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
Frigidaire FRU17B2JW Refrigerator Logo
37 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
