Question about Cub Cadet Garden
My Cub Cadet 1554 PTO Cluch is soking black smoke. It is turning, just greesed all my mower spindles
  • Matt Olenzek
    Matt Olenzek Nov 12, 2010
    Tony, Where is the somke coming from? the engine area or he deck area?
  • 293 Answers
Tony,
Your mower has a mule drive PTO. The belt starts at the clutch goes down to two idler pullys then back to the deck. You said you lubed the spindles, the only other moving parts (idlers) are preminently sealed. You cant lube these even if you wanted to, they do fail. The usually get loose, but sometimes the seize and smoke your belt. There is a tensioner arm on the deck, remove the tension, then (with the tractor off), spin by hand all of the idlers on the deck and the two up front on the tractor (mule drive). They should spin freely and quietly, if they are loose or wobble or make noise, replace them. Also while you are under there, spin the spindles (blades), they should spin freely as well, with no bearing noise or movement. The way to check that is to reach under, find the end of the blade and lift up on then pull down on, it should be tight. If it moves, the blade is either loose or the bearings are failing. These are the things that are the PTO components, All have to be working with freely moving parts, or you could have resitance that will smoke belts, or shred them depending on the failure.
As far as the clutch, it either works or it doesnt. With the tractor off and you sitting on the seat, turn the ignition to the run, not crank position. When you engage the clutch you should hear a "Clunk" when you pull the yellow knob. If so it works fine.
Hope this helps.
Posted on Nov 12, 2010
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Cub cadet gt 1554
check for bad switch or bad relay behind dash or bad pto clutch jump it with battry were it connects with pto connetor
Jul 06, 2014 | Garden
I have a cub cadet zero turn 50' mower, when the PTO is engaged both outside blades turn but the center one does not. What could be the problem
the spindle has broken in half inside the spindel take it in and have them to replace it it has press on bearing so they will have to do it
Jun 30, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Club cadet i have a noise when pto is engaged
have you taken of wire, could have done bearing in one of the pulleys or spindle housings probably the one that had wire around it
Mar 18, 2013 | Cub Cadet Lawn Mower Electric PTO Clutch...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Apr 08, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Apr 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
253 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
