Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on charger which took about 2 hours. I used blower and trimmer for combine total of about 30-45 minutes for edging and leave work and then battery had no more power and red light went. I recharged again but is it normal for battery to last only 30-45 minutes? I thought it should last for several hours. Is my battery defective? Thanks - JF
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
Posted on May 05, 2017
joboo1
  • 257 Answers
SOURCE: Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
Posted on Feb 05, 2009
SOURCE: New 18v Ryobi battery totally dead
Same Thing just happened to me, I bought a painter with two batteries. One battery did not charge. Took the kit back, got new kit. Two batteries will not charge.Charged them for additional 12 hrs, still no good. Returning them to Home Depot.
Posted on Feb 24, 2010
Testimonial: "My problem is that I took the tools to Guatemala so there is no taking back. "
  • 8 Answers
SOURCE: New Ryobi 18v lithium battery goes dead after a
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Posted on Apr 01, 2010
Testimonial: "The answer was very helpful. Thanks!"
HomePlicity
  • 41 Answers
SOURCE: Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Testimonial: "This is the best answer I received! Thanks!"
SOURCE: how do you take apart a ryobi lithium 18v one
This applies to Li-ion. NiCd is probably somewhat different.
Unscrew four security screws on the bottom of the battery. If you don't have the right bit you can grind down the center pins in the screw heads and use a T15 bit.
Unscrew the hex-head screw in the center of the protruding post at the top of the battery. It may be non-standard in size but a small metric hex key wrench works if you are gentle. The four corners of the battery cover should be loose now.
There are still two plastic clips holding the top cover to the main unit near the centers of the long dimensions. Gently push a knife blade into the crack between bottom and top to release the clip on each side.
As you lift the top cover off you should push down on the contacts near the top of the post so you don't pull on the attaching wires. Eventually the contacts should pop free and the top cover detaches.
Detach the wiring harness for the status LED from the circuit board. You can now remove the combined circuit board and battery pack from the lower case.
Six screws attach the circuit board to the battery assembly, along with several solder connections, but you probably don't need to go this far. You can now test and possibly replace individual cells.
Posted on Nov 16, 2010
Ryobi P2002 manual
Here it is
http://www.manualowl.com/p/Ryobi/P2002/Manual/111150
Apr 12, 2013 | Ryobi 18v P2002 String Trimmer P2102...
My trimmer only runs about 5 minutes on a fully charged battery, It seems to be overheating. If I let it cool off it will run again, but only for a short time. sometimes grass gets caught around the...
You sure the battery is fully charged. A bad battery will run a bit and then stop providing enough power. Then if you wait it will have "rested" and work another tad. Then rest again.
Almost sure that your battery is bogus.
Sep 22, 2017 | Ryobi 18v P2002 String Trimmer P2102...
Wish to purchase sparkplug rdj7y for ryobi blower vac where do i purchse from which australian store please female buyer help!
In the US hardware stores (DIY stores) or stores that sell car parts. Bring the old one in so that you can match the numbers. Also you will need to set the gap. that is the space that the spark goes across. It should have that number in the manual. I can tell you because we use thousandths of an inch. in the US.
Jul 03, 2011 | Ryobi 18v P2002 String Trimmer P2102...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I use the ryobi P110 charger with the P103 lithium-ion batteries ? Thank You
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
Dec 27, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Should I bring the battery of my Ryobi 18v grass trimmer inside for the winter?
Yes, and charge it up occasionally to keep it alive. Lithium batteries are costly and severe cold is not good for any type of battery.
Dec 02, 2010 | Ryobi 18v Lithium Grass Cordless Trimmer...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I leave my Ryobi P113 charger with a P103 battery inserted in it for an indefinite amount of time with the charger plugged in, without doing damage to the battery or charger? Thank you. Phil
Yes you can that is an automatic charger when it is fully charged it shuts down the charging portion but keeps the charged light lit however this does not effect the battery.
Aug 13, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
602 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
