Question about Maytag Neptune MAH6500A Front Load Washer
Shakes realy bad and shuts down.never gets up to full spin.
  • 134 Answers
Even with nothing in it?
Posted on Nov 12, 2010
When the machine is on spin the machine shake so bad that it jumps
If the drum has an unbalanced load any machine will shake like crazy during high speed spin cycle - some even have a buzzer and shut down! Rearrange the clothing in the drum.
Oct 28, 2015 | Washing Machines
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
My 1989 f350 duelly starts in am and dies quickly bought coil and ecm cap rotor and backfires and shakes and dies any ideas.i was thinking distributor or fuel pump please help
If you spray starting fluid in the air intake, does it stay running? I would go to harber freight and get a cheap fuel pressure tester and hook it into the fuel line. It hsould be about 40 psi, and hold for about 30 minutes after shut down without bleeding down too much, like 5 psi.
Try this too. Turn key to ON, wait 5 seconds for the pump to shut off. Then turn key off and listen for the realy to "Cclick" under the dash (about 10 seconds). Repeat this. Then start engine. This primes the lines & injectors if you are getting bleed down due to a bad check valve in the fuel pump.
report resuts. pleasre rate assistance.
Aug 12, 2011 | 1989 Ford F 350
WASHING MACHINE SHAKES REALY BAB ON SPIN CYCLE AND BOWL NOT SITTING LEVEL BUT MACHINE IS LEVEL
try putting less washing in it it sounds like its to full and un even weight hope this helps
Jul 25, 2011 | Maytag Washing Machines
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
The car idles up down very slightly its hard to notice unless you realy listen to the engine, when you shut the car off it jerks a little its like a shake , also sometimes when you are about to come to a...
Sounds like your 02 sensors are bad. This will cause speratic idle. Up down, up down. If it still fires a little after engine is shut off, then there is too much fuel in motor caused by faulty 02 sensors. This will also cause check engine light to turn on. The 02 sensors tell the computer how much gas to give to engine
Nov 09, 2009 | Honda Odyssey Cars & Trucks
My engines shakes really bad once it starts. it idles for a few mins then it shuts down. this is after it shut down on me on the freeway. all power went of and it just shut down on me. i think is the
I'm no bona-fide mechanic, but I've done a lot of work on cars. It may be you have an engine seriously out of timing. Or you might have loose or worn engine or transmission mounts. If the engine was shaking badly before shutting down, one result of that may be in the fuel system. If your car has a carbeurator, the shaking may have wreaked havoc on your float. If you have fuel injection, I'm not sure what to think.
Hopefully, you've gotten your precise answer before I even read your problem!
May 11, 2009 | 1996 Ford Explorer
Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machine Shaking
Please take the time to give this a fix ya rating
clarkco
Car shakes when I go over 45 mph
Did you have this problem before you got the tires? Sounds to me like the tires need to be balanced.
Dec 24, 2008 | 1989 Toyota Corolla 2 Door
Maytag Neptune MAH6500A Front Load Washer Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
