Question about Uniden (WNR-2004) 802.11b Wireless Access Point
Hello I am having problem setting up a password for this wireless router. has anyone else had this problem with it. We have computers hooked up to it. When you go on the network it does not ask for a password. I am just wondering how I can change the name of the network and change the pass word. I have accessed the router through the internet explorer. On the manual it tells you how to set up a passcode for accessing the router itself, but not a passcode for the network which I need.
  • Uniden Master
  • 3,992 Answers
You need to find a wireless security option in the routers menu.
The term is Wireless encryption WEP type encryption. The network name is not the correct term what you are referring to is called SSID and is the name of the wireless network.
If you want to change the default configurations, you will need to
access the browser-based utility of the WNR2004 AP and select
the Wireless Configuration from the menu on the left hand
side
pg 42 of https://www.manualslib.com/manual/374326/Uniden-Evolo-Wnr2004.html?page=42#manual
Posted on Jun 11, 2017
Can anyone provide me with the easiest way to hook up a wireless router for hughesnet satellite hn7000s series. i've tried the dlink dir655 and couldn't get it to work and now thinking the e1000 or 2000...
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Connect internet lan cable from modem to router's WAN port. Let me know if you need further assistance. Thanks for using FixYa.
Mar 06, 2011 | Cisco Linksys E2000 Advanced WirelessN...
WPA KEY?
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
May 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do I get the password in order to hook up a new laptop?
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network
Mar 07, 2010 | Actiontec GT704WG Wireless Router...
How to hook up a netgear router to make computer 2 a wireless system(comp.1 is desktop and 2 is also) recently changed from dial up to a verizon wireless system but not sure how to hook it all up.
You need to install a wireless card in computer 2.
Then install the wireless driver for this card.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 26, 2009 | NetGear WGR614 Wireless Router
How do I secure my network. I have a Linksys Wireless-G 2.4GHz 54Mbps broadband router?
Nov 13, 2009 | D-Link DI 514 Wireless Router (DI-514)
Hello - anyone there?
3. Enter the router setup login and password
6. Setup encryption key the strongest is WAP2
7. For further secutity measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
10. Remove the LAN cable and the computers should be able to connect to the router.
Sep 28, 2009 | Siemens SpeedStream 2624 Router...
I have problem? how can we connect router in
- Check physical connection (Connect the modem to the WAN or Internet then hook one of the computer to the LAN connection.
- Open a browser then access the configuration page of the router.
- Under on tools create user ID and password.
Another is:
- Open the wireless settings under setup.
- Change the wireless network name/ SSID and set the encryption or security to WEP or WPA.
- Check the wireless network connection if you can log in with the wireless network name/ SSID with the password.
^_^
Feb 18, 2009 | Blitzz Technology (BWA611) Router
Not able to hook this router up
on the right track
connect modem to router WAN port
connect pc to modem LAN port by cable
DO NOT use wireless to configure router
http://192.168.0.1 is the address of the router
the admin name is 'admin' no quotes
the password is blank, not the word 'blank' a blank screen.. unless your sister changed it
read the online help
set an admin password
set a WEP encryption password
after config router can use wireless if prefer
NEVER make config changes by wireless
Oct 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless router
If you have a computer wired to the router, Try this steps.
1.Open a browser and then go to http://192.168.1.1
2. Username admin and password is password
3. You should be able to access the router's utility page then and get the wireless settings of the router.
Once you get the wireless settings of the router, just connect to the name(SSID) you set up and then connect to it.
Apr 25, 2008 | NetGear WGT624 Wireless Router
Setting passwords on dell truemobile wireless router
Hello, The default address for the dell truemobile 1184 is 192.168.2.1 If you have changed it and forgot, unplug the router (elec) for 5 seconds. This will reset it to default. The default SSID is "wireless". If a user ID and/or password is asked for enter "admin". Here you can change settings, enable broadcast, change SSID, enable WEP or WPA. Hope this helps.
Mar 16, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
See all Uniden (WNR-2004) 802.11b Wireless Access Point Questions
Uniden (WNR-2004) 802.11b Wireless Access Point Logo
Top Uniden Computers & Internet Experts
castletech
castletech
Brett Duxbury
Brett Duxbury
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
