Question about Dishwashers
The rinse aid dispenser is full but the dishes are very wet after they are cleaned.
  • Dishwashers Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Posted on Nov 12, 2010
2 Suggested Answers
  • 154 Answers
SOURCE: the some dispenser and the rinse aid dispenser
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Posted on Oct 21, 2009
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    The dishes are still wet after "drying" overnight?
    With the energy efficient dishwashers today it is very important to use rinse aid for proper drying. The rinse aid will help sheet the water off of the dishes prior to the dry cycle. If you do not use rinse aid you can expect poor dry performance.
    Next to the detergent cup in the door is the rinse aid dispenser, be sure it is full. You only need to fill it about once a month. There is also a product called "Turbo Dry" that you can use in the rinse aid dispenser, it helps dry even plastics very well.
    Next be sure you have selected heated dry on your options.
    Sani Rinse will also help as it heats the water before the dry cycle.
    Let me know if you have questions.
    Aug 01, 2010 | Whirlpool DU1055XT 24 in Builtin...
    Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
    the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
    Mar 04, 2010 | Dishwashers
    Dishwasher starting to leave soap film on dishes. It is a 2 year old Kitchenaid. Cleaned filter, no changes in our soap or water.
    First check the salt dispenser located at the bottom of the machine under the bottom rack,make sure it is full,then also check the rinse aid dispenser is full and adjusted correctly,in the rinse aid dispenser it will have numbers turn the dial to about number 2 this is average
    Dec 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
    My dishwasher is now leaving my dishes cloudy. What causes this?
    Make sure that the rinse-aid(jet dry) container is full. If it is full have you noticed if it's level has not dropped. It is possible that the rinse-aid dispenser is plugged. This will cause the dishes to be cloudy. You can also try running the dishwaher empty and add a cup of vinegar to the bottom before your start. There is also this stuff called "dishwasher magic" that you can try running in the dishwasher to clean it. Try using a soap with the rinse-aid in it or install a basket with a rinse-aid tablet and see if that helps clear up those cloudy dishes.
    Nov 08, 2009 | Frigidaire Dishwashers
    My dishwasher does not always dry the dishes completely - even though I use the same cascade with each use.
    The most important thing to getting the best drying from this energy efficient, water conserving dishwasher is keeping the rinse aid dispenser filled. In my part of the US, I only see a rinse aid called Jet Dry.
    The Cascade is the detergent powder and will not help the dishes to get dry.
    Note: Even with the rinse aid full, some plastics will still be wet.
    Aug 14, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
    Rinse aid not being released
    Most likely the actuator for the rinse aid dispenser is not functioning.
    Jan 13, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
    Indesit D63 dishwasher dishes not getting clean
    Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
    Jan 23, 2008 | Dishwashers
    Dishes are wet and the not drying
    Try using just the rinse aid in the tablets, don't put anymore rinse aid in the dispenser(This may take a while for it to empty) this should help with the drying.
    failing that look at manual that will tell you how to put the extra heat programme on
    Deep Diver
    Dec 22, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
    Dishwashers Logo
    73 people viewed this question
    Top Dishwashers Experts
