Question about Sony Playstation 3 (PS3) Console
For my PS3 There is no audio/video output for either the HDMI or Composite outputs
  • 53 Answers
Your playstation should always come with 2 specific adaptors. One for power, the other which connects to your tv with yellow, white, and red cables. The yellow, white, and red cables are audio and video.
Hope I was help!
Posted on Nov 12, 2010
I need a manual for a sanyo DWM-3000.
What outputs does the Sanyo have?
Composite output? (Yellow, with RED/WHITE stereo audio)
Component output? (Red/Blue/Green video with Red/White audio)
HDMI output?
Coax? (Audio & video combined)
What inputs does the TV have?
Coax?
HDMI?
Component?
Composite?
Feb 14, 2014 | Sanyo Televison & Video
Cant hook up my ps3 to the tv ? tried all 3 input outlets and nothing tried hooking it up with a dvd player and still nothing ?
The ps3 has 2 output modes, hdmi and composite or component. For example if you started with composite and switched to hdmi the screen would show up black. The way to select the dif output is to press and hold the power button until you hear a second beep, this should put it on the proper output. Hope this helps and is the only thing I can think of if your tv is properly working.
Aug 23, 2011 | Audio Players & Recorders
Ps3 hdmi to dvi blank screen no sound
Sometimes the PS3 automatically outputs it's video and audio signals in composite form. Try going back to your original composite cables and setting your system to output in HDMI. Those options would be under "Display Settings". Hope this helps!
Apr 13, 2011 | Samsung TX-P3264 32" TV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
The new AV cable will not fit into the slot in the ps3. Used a regular composite cable prior to trying the new HD cable.
connect the hdmi as normal , then use the composite cable to the headset and in audio output settings enable audio multi out , that will output audio to both the hdmi and composite audio jacks .
click here to download repair guide... u can do this by yourself....
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
No picture when hooking component through receiver. Get sound but no picture. Tried to put ps3 in input 1, 2 and 3. Tried multiple cables as well
with Denon you have to go into the menu and "assign" the inputs.
You have to select if you are using HDMI, s-video composite etc.
If your unit has upconverting remember that it will upconvert a s-video signal to HDMI but not the other way around.
HDMI is a digital signal composite, s-video etc are analog therefore you could not use the HDMI output from your PS3 but then use the red, blue green composite outputs from your receiver to run to your tv.
Dec 29, 2009 | Denon Televison & Video
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
