The outside unit is no0t able to start the fan spinning on its own. I have been able to manually engage the outside fan by turning the unit off, turning it on, and then manually spinning the fan when it starts up. The unit will then engage the fan and runs fine until the next cycle when it cannot start the fan on its own again. Can you tell me what part needs to be replaced and about how much it will cost?
    President:
  • 1,796 Answers
Hi!!
The part you need is called STARTING CAPACITOR and it is located in the same compartment where the electrical connectors are in the outside unit. MAKE SURE THE POWER BREAKER IS OFF before opening the compartment. and before working with the capacitor, touch both terminals with a screw driver to short them out and discharge the capacitor. Don't worry this is just a preventive measure and no sparks are going to be coming out of it. Once the capacitor is discharged, take a picture of the wiring and label them before disconnecting the wires. Remove capacitor and take to an appliance parts store to get a new one.
HERE IS A PIC. OF HOW A CAPACITOR LOOKS LIKE
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 12, 2010
  • Mister2You Nov 12, 2010
    Thanks kbron...can I get to the capacitor from the inside of the rv, or will I have to do this work from the roof on the outside? Also, where can I find an outside COVER for my Elect-a-Heat Mach EL? Mine broke and blew off coming across Southern California.
    Thanks again. john at mrmsje@yahoo.com
  • Rene J Solis Nov 12, 2010
    Hi!!
    Absolutely, turn OFF the breaker, remove the air return grill and filter and you should be able to see it, if not it is behind the panel where the electrical connectors are. While you are there, wiggle all the wires, and pass the screwdriver thru all connections terminals to make sure they are tight, on RV's, with the vibration they then to break away from the terminals. Here is a site where you can find the cover for your Elect-a-Heat Mach EL http://rvcomfort.com/rvp/ . Check the Technical Info section, there is a lot of good info there for RV owners.
    Good Luck!!
Ruud. How do I repair?
It is likely that the fan will have to be replaced.
Jul 13, 2015 | Heating & Cooling
Rheem outside unit humming, fan not spinning
there is a dual cap in unit. kill the power and remove the silver cylinder. on top it has 3 places it can put wires. F, H, C. write the colors of wires and where they belong. take part up to granger and buy. 30 bucks most. replace. if same problem do the same with fan motor, around 60.
Jun 18, 2013 | Heating & Cooling
My outside amana prestige ac unit ( rcb30c2a) gets very hot when it is turned on, but the fan does not turn.
Hello, try spinning the outside fan with a stick or a small object you can spin the fsn blades with, if this gets the motor running the capacitor must be replaced. If the motor does not start by manually pushing it the motor will have to be replaced.
Jun 30, 2012 | Amana Heating & Cooling
Ruud Achiever® Series 13 SEER the fan will not spin I have checked the breaker is there a reset button inside the unit?
There is a reset button on the outside of the unit near where the tubing and wiring comes into the unit. The button is encased with a red plastic cover. If the unit is making noise but the fan is not spinning, the problem may be related to the fan itself. First with the unit turned of, see if the fan spins freely. Then fire the unit up again to A/C and see if the fan is not moving. If not, carefully nudge the fan blade with screw drive in the direction it normally moves. if the fan engages, most likely the bushings are old and need to be replaced; RUUD may only sell the entire fan assembly.
Aug 14, 2010 | Air Tools & Compressors
A/c outside unit is not working- fan will not work.
I assuming that the black box is a 100 amp breaker, which is connected to your condsensing unit (outside unit). If you open the box and pull the fuse then this will turn off/kill the power to your unit. As far as the buzzing noise it could be that the contactor is engaged. Hopefully, your fan motor is burnt out or the capicator is bad. If you take the access cover off and check for voltage at the contactor you should know if it is the fan motor. The voltage will come in at the bottom T1 T2 T3, once the contactor is engaged L1 L2 L3 will have the same power. Of course if your contactor is not engaging then thats the probelm, you can manual engage the contactor by pushing it in. There will be four wires two running to the capicator and the other to the contactor, these are the wires that control the fan motor. The other three wires run to your compressor. Hope this Helps Tim
Aug 03, 2010 | Heating & Cooling
AC not blowing cold air
Remove the outside fuse from the unit that is not cooling... remove all the sheet metal from around the outside unit.. see if there is a lot of grass/weeds/ bird nests, or other material in the coils.. if there is... use a high pressure hose to clean the coils completely!!!!! (I had this done to mine...worked much better!!)..if this doesn't help,, I am afraid it might be time for some freon... and yes..its $$$$...
Aug 11, 2017 | Amana Heating & Cooling
Outside unit not operating. Outdoor Unit fan (fan
the fan motor is burt. replace it. it will still spin if you manually engage but it will overheat an may even cause fire, also that waste tremendous amount of electricity now.cap is not defective,
Jul 04, 2009 | Heating & Cooling
Trane XE 1200 ac The outside fan stopped
unless you have a meter youneed to see if the unit is asking the fan to turn on. if so the fan (which i doubt) maybe gone bad or the starting capasitor for the fan... is there anyway of checking the voltage to the fan
Jun 22, 2009 | Heating & Cooling
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
Toutside a/c unit fan quit spinning
sounds like starter on a/c is going out you need to replace it as it starts the fan and compressor as well good luck (thats assuming toutside means outside)
Aug 23, 2008 | Heating & Cooling
Heating & Cooling Logo
152 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
