Question about Sony KP-65WV700 65" Rear Projection HDTV
Screen goes off after a few seconds
The unit powers up and the guns light. Then the Red gun indicator light inside the unit illuminates. It then shuts the entire system down. Any suggestions. It will repeat the process as often as I hit the power button-
Thanks for any suggestions.
DaveBendall@comcast.net
    Problem Solver:
  • 3 Answers
The red tube is going out. I have the same problem with my Blue tube. If you get rid of your TV I will buy your blue tube.......
Posted on Sep 18, 2008
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Have a Sony KP-65WV600, already replaced d board once, and replaced convergence ic's once also. Now as soon as I turn unit on, turns to red screen and shuts off, video that is, audio works ok, noticed...
Check High voltage Block.After replacing ic's (STK convergence ic's) you need to adjust Black&White scale.Turn ALL screen adjustments to min.Turn TV on and adjust screen slowly for each gun (I would start with Red first ) when you came to point that you see red background with white lines across, at that point G2 is too high (that will cause TV to shut down,don't worry just lowered adjustment and turn tv back on) so adjust to proper voltage and do the same for each gun.After that, adjust focus for each gun (again all controls are on High Voltage Block and HVB is mounted on front of your tv after you take speaker gril out) black box with 6 controls' screen RGB, focus RGB .
You should do that in dark room in order to get perfect Black&White scale,when all guns are adjusted properly you will see grey picture.Make sure 'Color" adjustment on your display is down to 0. Another step is convergence adjustment ,Flash Focus etc.If TV stil shuts off after all, your Red picture tube is short inside,take crt pcb from tube,make sure TV is unpluged from power before that, and turn Tv on .If stays On tube need replacment...good luck)
Aug 22, 2011 | Sony KP-65WV600 65" Rear Projection...
I was playing my playstation 3 and all of a sudden it shut down and began to blink a red light. It did this a second time. What is wrong with it? Please help?
Your problem is yellow light of death which can be fixxed with heat gun hot air gun and the right person or your power supply internally is going out.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
Ps3 does not turn ON
looks like the YLOD, you can search some fixes of refloating the solder with a heat gun or take it to a repair shop. lastly and most expensive is sending it into sony assuming its out of warranty if it is its 150 to fix it. If still under warranty then call them asap.
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
I was playing and my system shut off. the indicator light was blinking red. i hit the power button once and the indicator light went back to a solid red light. i tried turning the system back on and the...
You need to have the motherboard fixed, do to so you need to take the PS3 apart then reflow the board.
there is a great 6part video guide on YouTube to view for free. 6 videos from the same fellow, each video about 10mins long, goes over everything for you.
http://www.youtube.com/user/gilksy1 and its free unlike some eBook site.
I actually used the videos shown by this guy to fix about 30 PS3 units with no problems, you just need a few things though like a heat gun and some thermal paste. sounds hard, but it's very easy once you start!
Hope this helps in some way.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
My ps3 starts to turn on for 1 second. Yellow light flashes, system shuts off, and red light blinks. Help?
HI, this is an emergency shut down, due to overheating. the yellow light is an indicator of a previous overheating issue that has damaged the power unit.
unplug the unit and, let it sit for 10 minutes to cool. after the cool off, plug the unit into the wall socket once more and, power up. if it continues to shut down and, flash the red light, this will confirm a major fault within the power unit. Contact Sony for the replacement of the power unit in this case.
***NOTE(If the unit begins to play normally after the cool-down period, you will need to purchase a cooling device to prevent future overheating issues).
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
No red in the image on the screen
The adjsutment that you turned down was the G2 voltage to the red tube which is just a temporary fix for a CRT which has a short developing in it. Try turning up the red adjustment again only slightly to see if the red CRT ( tube) will light up
if it does and then the set shuts down its most likely the red CRT which is bad . If it lights up but you get retrace lines but doesnt shut down it possible that its the CR board ( Red CRT Drive Board) which is at the very bottom of the red tube.
May 26, 2009 | Sony KP-51WS500 51" Rear Projection...
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
TV shuts off and red standby/timer lights blinks red until I power the set off. When it shuts down it does so with a very loud snap. When I turn it back on the screen is blue and has light blue...
The most common cause for what you are seeing is a shorted gun in the picture tube. When 2 elements (heater and cathode) of one of the guns inside the neck of the picture tube touch, that gun goes full on and overloads the flyback (high voltage) transformer. If it is in the blue gun, the screen will go bright blue with light blue "retrace" lines in it. The computer senses the overload and shuts the set off. At 2 years old the tech most likely tried removing the short by arcing between the elements. This works sometimes but the short often comes back a few months later. Another attempt at removing the short could be tried, and it might work this time, but it may or may not work for long. The ony other solution is to replace the picture tube but that would cost much more than the set is worth. A qualified tech will be able to tell you if this is the problem in your set.
Aug 21, 2007 | Sony KV-35S36 35" TV
Sony KP-65WV700 65" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
