Question about Honda 8 HP Engine
Powerwasher isrunning water is on squeeze handle and spray surges
    President:
  • Honda Master
  • 1,388 Answers
When spray surges, the unloader is activating. Make sure that tip is not clogged. Test with a different tip / nozzle that is correct size for your machine (gpm is marked on tip ). If changing the tip does not help, reduce the pressure at the regulator. As the unloader wears, it will not hold pressure to the point that it will need to be replaced or rebuilt (replace with new is best) .
Posted on Nov 12, 2010
My unit heats up, has plenty of water, but will not spray, pressure is at 4
Sounds like a blocked nozzle. I would soak it in line Away or used a safety pin to clear it
Apr 28, 2016 | Vapor WhiteWing Steamer Canister Vacuum
I have a troy bolt power washer and it won't pump
You need to give more information. Does the motor stall when you squeze the handle? Does the spray surge and the motor run well? Does the spray surge and the motor surge as well? Does water come out of the bottom of the pump? Does nothing come out of the spray gun when the trigger is squezed?
All of these symptoms point to different problems.
What does your machine do?
Oct 24, 2014 | Garden
Powerwasher pw1800u
The water pump is pretty much shot! Did you crank the pressure washer without the water being on? Most times you see this when this occurs.
Jul 13, 2013 | Garden
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
I have a Honda GC160 motor on a powerwasher. The engine stalls when I release the power wand handle, but if i keep the handle squeezed, it works but the engine sounds like it is laboring.
replace the unloader of your pump....find the model of the PUMP ...not the washer itself...the pump and find a parts list and then purchase and replace the unloader. That will fix your problem. Good luck
Aug 15, 2017 | Honda Garden
Low pressure from powerwasher wand when trigger is squeezed
THIS POWER WASHERS ARE TRICKY, TO OPERATED YOU NEED TO OPEN THE WATER FAUCET CONECTED BY A HOSE TO THE POWER WASHER , OPEN THE TRIGGER AND THEN START THE POWER WASHER, OTHER WISE YOU WILL RUIN THE POWER WASHER PUMP.
Nov 01, 2010 | Briggs & Stratton Garden
The power washer is surging cuting in and out when i turn da nozzele to get stronger water pressure?
When I use my machine I hook up the water to the pump, hook up the high pressure line and gun, then turn on the water full and squeeze the triger to make sure all air is out before starting the pressure washer(mine is gasoline powered). Then I install the nozel on the spray gun. If you are having surgeing water pressure Check the hose washer where the water hose hooks to the machine, and be sure the supply hose is not restricted and valve is on full.
If this was helpful please leave Feedback. Thanks, SP
Oct 20, 2009 | Garden
When I squeez the handle the pressure surges.
Hi:
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Powerwash proheat
If the unit is spraying ok but your just not getting hot water you could have a defective heater even if the light is on. To test you would need to take the handle apart and see if the heater gets hot by touching it give it about 2 Min's to heat up but be careful it will burn you if it is working properly. Another thing to remember is that even if it is working properly the water won't be very hot especially if you put cold water in it to start out with. The best thing to do is fill it with the hottest water you can get from the tap don't boil it or anything but this will help. If you need any parts or cleaning solution for this machine or any other visit www.stevessewandvac.com .
Jul 07, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Honda 8 HP Engine Logo
131 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
