Question about Zebra P330i Thermal Card Printer
Printing in black mono only. A portion of the
Printing in black mono only. A portion of the required text is not printing clear and sharp black, with some of the letters not printing at all. The majority of the text is very clear and sharp, but approx 10 letters are irregular in the print quality.
  • 20 Answers
Common problem is a dirty card, make sure you handle the cards by the edges and not the surface as oil from finger residue will cause a misprint on that part.
This problem can also be caused by improper or too low of a setting for black intensity, where the printer does not apply sufficient heat to transfer the color onto the card.
Also check for a faulty ribbon, if the ribbon is not properly stored or is more than 3 years old, it can also cause this issue.
-- The Pros at www.DiscountIDStore.com
Posted on Feb 10, 2012
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
That paola give horrible descriptions. Do not go one way then the other with the print head angle screw unless you are positive nothing else will work. He is correct about 1/4 turn increments to adjust the angle, but start with one direction and do 1/4 turn until you have done two complete sets. if not better reset it to it's original position and then try the other directions.
Posted on Oct 19, 2012
    Champion:
  • Zebra Expert
  • 285 Answers
The printhead need calibration,
go to driver, send the comand !SA ( to be use with with color ribbon), if still doing, lose the two screws from front plate(printhead), insert card under the printhead, send comand !D (printhead down) !M (printhead up (do it 4x), with the printhead down (!D) tie the two screws (the front plate is done. (next print test card, send command (IM).
If still have problems, louse the side screw carfuly but secure the big screw at the front of the printhead to don`t coming out with the spring,
move the front big screws 1/4 to one side, and print a testcard, do it from one side to another until have best quality print.
Posted on Nov 12, 2010
Not printing any black text on paper.
Following Occam's Razor, the first thing to do would be to replace the black ink cartridge.
May 23, 2016 | Canon PIXMA MG7120 Inkjet Multifunction...
How do i clear the error code F2-64 on Sharp MX-3500N
F2 64 TONER SUPPLY ABNORMALITY ERROR (BLACK)
Have you tried replacing the Black Cartridge ?
Dec 17, 2014 | Sharp MX-3500N Laser Multifunction Printer...
Does printing black text only on a Brother Inkjet All-in-One (MFC-J625DW) use the color cartridges?
Your right. Simple answer. Take the coloured cartraiges out (you may need to set your printer to mono crome though. not sure.? Save a bit more money and recycle your cartrages you get paid for them. then you can buy refill cartrages and save even more. Some say do not use them they cause problems, but i have from day one and still have no problems 29 years later!!! and i am a high user on a A1 PRINTER!!! (draughtsman if your wondering)
Jan 25, 2012 | Office Equipment & Supplies
Printing colour quality problem on canon irc2620n laser printer
Are you service technician?
You can try to clean the laser unit, try to clear dc-con like on clc3200, but first try gradation adjustment.
If you not an technician do not try to clean laser by your self
Feb 01, 2010 | Canon imageRUNNER C2620 Color Copier
Ricoh CL7000 text is blurry/fuzzy
probably only when printing in colour? Black only, is ok right?
It needs to have it's line adjustment procedure done. This is a series of complicated trial and error adjustments performed in service mode that the individual colours are adjusted based on printouts generated by the printer. Can only be adjusted by a service tech with experience with this adjustment.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Print black w/o color ink cartridges loaded
No, in general all current inkjet printers require the installation of a color cartridge even if you want only black printing.
(If you had an old cartridge "Empty", you might be able to purchase a resetter (Epson) and set you printer to print in black only.)
You can, set up your computer to print in black only by selecting Mono printout in your print set-up.
There are a few Canon printers (Older) that used to print in Black or Color only printing....but no longer available......
Feb 09, 2008 | Office Equipment & Supplies
Printer malfunction
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Jan 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Zebra P330i Thermal Card Printer Logo
585 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
