Question about Casio Cameras
Lens errror - Casio Cameras
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 12, 2010
My camrea said focus error will not do nothing
The lens error/focus errror is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 07, 2011 | Sony Cameras
When I open my Canon A570 camera, The lens stuck, and it says on the screen :"lens errror - restart camera". What can I do? Thanks, Nati.
This message ' lens error - restart camera ' is usually shown under the following condition.
An error was detected when the lens was in motion and the power has been automatically turned off.This error can occur while you hold the lens when it is in motion or you operate it in a location with excessive dust or sand in the air.Try turning the power back on, and resume shooting or playback.If this message continues to display it shows a problem with the lens and you have to open and repair it which I would not prefer as it can affect the fine mechanics inside the camera.You can contact the Canon Customer Support Help Desk from the following link. ( http://www.usa.canon.com/cusa/consumer?pageKeyCode=requestRepair ).Your valuable feedback would be appreciated if satisfied with my solution.Thank you.
Jun 09, 2011 | Canon PowerShot A570 IS Digital Camera
KEEPS SAYING BAD DISC
The Disc is not being read by the optical head and so the processor says there is errror in gettting data.
the most possible chance even after cleaning of the lens eye of the optical unit is to replace the laser head ( optical ) assembly.
Make sure that you are installing a new one with precaution , not forgetting to remove the static short in the new head before installation.
Sep 18, 2010 | Jensen 8.5'' Overhead DVD Player Package...
CD player will not read the CD and flashes errror 5
A common problem seagull, you might try getting hold of a cotton bud (women use them for cleaning babies ears and noses) and gently clean the laser lens. On some machines you may need to remove casing to expose the lens. You can't miss it when you see it, it is the device which fires the laser onto the CD. Switch off power before removing casings though dude unless you like receiving high voltage shocks.
Apr 02, 2010 | 2005 Hyundai Sonata
E 18 errror
The following blog outlines some repair options for an E18 lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2009 | Canon PowerShot S2 IS Digital Camera
I dropped the Camcorder, SONY DCR DVD108 and now get an errror message E61:10. Can you help fix it for a reasonable amount or should I just buy a new one?
Error E:61:10 means that some elements of your lens system were misaligned. Now the simplest way to get rid of this problem is to do the very thing that caused it in the first instance. Bang the lens in a controlled manner against a hard surface(wood is preffered) while switching it off and on several times until the fault goes away . dont continue banging it when the fault goes away!
Good luck.
Sep 27, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Our camera was dropped this morning--now it reads Lens Error
oh no! you need to get the camera checked. there might be a lens that got dislocated inside the camera. Nikon is pretty fragile. Get it fixed asap or moist will damage the lens and it won't work anymore.
Sep 03, 2009 | Nikon COOLPIX S10 Digital Camera
Lens Error Problem
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
May 19, 2008 | Nikon Coolpix L11 Digital Camera
Cameras Logo
63 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
