Question about Frigidaire FRT18G4A Top Freezer Refrigerator
Will the freezer work after being plugged in 6 hrs after transporting it on it's side?
  • 1,531 Answers
Yes it should be fine how ever you may need to run the unti for about fifteen minutes then shut it off four half hour or so then start it back up you should not have nay problems with it./
Posted on Nov 12, 2010
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
Amana upright commercial freezer not freezing
did you lay it down during transport .if so it needs to stand unplugged for 24 hours .the oil will have run out of the compressor
Sep 26, 2016 | Amana Refrigerators
Can I transport a woods upright freezer in a horizontal or close to horizontal position?
not the best way to do it, but if you must, just when oyou getit to its final destination leave standing up for at least 24 hrs before restoring power... you dont want oils from compresoor circulating through unit.. give it the full 24 hrs
Oct 13, 2010 | Woods Upright Freezer MU07W
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The fridge andf freezer is not cold at all
This refrigerator has an adaptive defrost control which has been an issue. You can tell if frost is building up on the back wall of the freezer hence a deferost problem. For an immediate fix, unplug for 4 to 6 hrs with freezer door open, plug in it will work for about 10 days till you can buy this part. It is located in the top back upper fridge side two phillip head screws and 4- 1/4" hex head screws, unplug when installing. It may have to be defrosted again if doors are opened too often.
Jul 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Briefly unplugged and now when plugged back in freezer wont turn on?
fairly unusal but ...posibly vapour locked.... people transporting fridges and freezers laying them down or chest freezers standing them up in a truck or trailer (taking them to the cottage) have this problem all the time unplug it for 24 hrs should cure it Good Luck
Oct 12, 2009 | Frigidaire 13 cu. ft. / 368 liter Chest...
Can I transport a whirpool side by side refrigerator / freezer, laying it down on it's side for 5 hours?If when I reach my destination I stand it upright for 48 hrs. before I plug it in.
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Jul 17, 2009 | Dometic RM2193 Compact Refrigerator With...
Freezer quit working
I suspect when you lifted or moved the freezer, you tilted the compressor such that the oil washed out into the refrigeration lines. Common when people tilt refrigeration equipment the wrong way.
Jan 30, 2009 | Freezers
Warm fridge cool freezer
Hi folks,
IS, the freezer so packed full with packages that they are covering the air vents in the freezer that must be open to share the circulation with the fridge?
Let me know!
If not keep calling the server and pay him only when he fixes it!
Sep 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRT18G4A Top Freezer Refrigerator Logo
69 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
