Question about Microsoft Windows XP Professional SP2
Hi, I have a very critical problem in windows xp. conime.exe loads everytime windows starts. it make system very slow. tried to remove from startup and delete the file from the location (c:\...\system32\conime.exe). but it reappears after few seconds after i delete. tried the same thing in safemode and tried deleting the registry values too. but didnt help. system restore didnt help. tried symatec corporate, symantec endpoint security, nod32, malwarebytes, asquared, bghost remover, trojan remover, panda activescan.. nothing helped.. Instead trying these I could have formatted, but i dont want to do that.. Formatting is not the only solution.. there is something but I dont know.. I am in a desperate need of help.. thanx in advance
  • 340 Answers
Description:
conime.exe is a process which is registered as the BFGhost 1.0 Remote administration backdoor tool. This backdoor application can allow attackers to access your computer, stealing passwords and personal data. It is a registered security risk and should be removed immediately.
Follow this link for a removal tool. download and install malwarebytes and run a full scan.
Follow the prompts once the scan is complete to remove the infected files.
http://download.cnet.com/1770-20_4-0.html?query=malwarebytes&searchtype=downloads&filterName=platform%253DWindows&filter=platform%253DWindows
Posted on Nov 12, 2010
How do i make my pc fster
Slow Windows Machine! Try disabling startup programs. Go to Start > Run and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM.Uninstall any extras like those pushy toolbars, and add-ons.
Dec 06, 2012 | Microsoft Office 2010 Professional 32 64...
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
Everytime i open my computer, ah pop-up windows say's WINDOWS CANNOT FIND SCVHOST.EXE
First, I'll let you know what's going on, then I'm going to post from Microsoft, what svchost.exe does, and how to find out where the problem is. I can help you further if you need it.
Svchost.exe is a program in WIndows XP Pro that will start services in your computer during startup. It sounds like you have deleted a program and "service host" is still looking for it to open on startup. This can happen if the program was removed without using the correct removal procedures. It is still listed in the registry and your computer is still trying to access it. DO NOT edit your registry unless you know what you are doing. You could create a catastrophic failure of Windows. There are programs that will remove registry entries if those entries are no longer valod. You can fing a free program for this function at web sites like www.nonags.com
Following is information from the Microsoft web site:
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the following registry key, whose Parameters key contains a ServiceDLL value: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Service To view the list of services that are running in Svchost:
  1. Click Start on the Windows taskbar, and then click Run.
  2. In the Open box, type CMD, and then press ENTER.
  3. Type Tasklist /SVC, and then press ENTER.
Tasklist displays a list of active processes. The /SVC switch shows the list of active services in each process. For more information about a process, type the following command, and then press ENTER: Tasklist /FI "PID eq processID" (with the quotation marks) The following example of Tasklist output shows two instances of Svchost.exe that are running. Image Name PID Services
System Process 0 N/A
System 8 N/A
Smss.exe 132 N/A
Csrss.exe 160 N/A
Winlogon.exe 180 N/A
Services.exe 208 AppMgmt,Browser,Dhcp,Dmserver,Dnscache,
Eventlog,LanmanServer,LanmanWorkstation,
LmHosts,Messenger,PlugPlay,ProtectedStorage,
Seclogon,TrkWks,W32Time,Wmi
Lsass.exe 220 Netlogon,PolicyAgent,SamSs
Svchost.exe 404 RpcSs
Spoolsv.exe 452 Spooler
Cisvc.exe 544 Cisvc
Svchost.exe 556 EventSystem,Netman,NtmsSvc,RasMan,
SENS,TapiSrv
Regsvc.exe 580 RemoteRegistry
Mstask.exe 596 Schedule
Snmp.exe 660 SNMP
Winmgmt.exe 728 WinMgmt
Explorer.exe 812 N/A
Cmd.exe 1300 N/A
Tasklist.exe 1144 N/A
The registry setting for the two groupings for this example are as follows: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Svchost:
Netsvcs: Reg_Multi_SZ: EventSystem Ias Iprip Irmon Netman Nwsapagent Rasauto Rasman Remoteaccess SENS Sharedaccess Tapisrv Ntmssvc
RApcss :Reg_Multi_SZ: RpcSs
Jun 18, 2009 | Microsoft Windows XP Professional for PC
My windows cannot open exefile and I cannot install spybotsd162.
Dear johan_poliwa, ur windows installer has corrupted or have been deleted. The best possible solution is that u format ur OS.
Mar 19, 2009 | Microsoft Windows Vista Home Basic Edition
Windows Startup Error csrss.exe
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
Feb 14, 2009 | Microsoft Windows XP Professional
Zone Alarm will not start up when I turn on my computer?
You can ADD the "Zone alarm" executable to your windows startup.
This can be done in 1 simple way.
1. Locate the "Zonealarm.exe" in your "Program files" folder. Usually your Program Files folder will be here "C:\Program Files". Just run a search for "Zonealarm.exe" inside this folder.
2. After locating the "Zonealarm.exe" file, right-click on that file. And select "Create Shortcut".
3. After that you'll find a "Zonealarm.exe" Shortcut file or icon inside the same folder.
4. Just COPY or CUT the shortcut file.
5. Now Right click on the "START" button.
6. Select "Open all users".
7. This will open a windows explorer window. Locate "Programs" folder and Enter it.
8. Inside you should locate "Startup" folder and enter it.
9. Once u ar inside the "Startup" folder, paste the already copied "Zonealarm.exe" shortcut file.
10. That's it. Now try re-starting the system.
Thanks
Dec 18, 2008 | Microsoft Windows XP Home Edition
My computer is trying to configure and load windows photo gallery but it keeps saying I do not have the CD Rom I do not want to load this program I cannot seem to cance it and when I go into remove...
  • Click Start .
  • In the Start Search field, type msconfig, and press Enter.
  • The System Configuration window opens.
  • In the General tab view, select Selective Startup, and remove the checkmark next to Load startup items.
  • Click on Startup TAB
  • Under Startup TAB uncheck all of the Items except Following:-
  • For Windows Vista
HD Audio Control Panel.
HP KBD EXE.
Hp digital imagine - hp all-in-one series.
HPRun.
Hpsysdrv.
HP Total Care Advisor.
Microsoft Windows Operating System.
NVIDIA products.
Symantec Technologies products.
Windows Defender.
  • For Windows XP, do not disable the following startup items:-
Alcxmntr
Atiptaxx
ati2mdxx
Backupnotify
Ccapp
Ccregvfy
HPBootOp
Hpsysdrv
Kbd
LTMSG
NvCpl
ps2
Recguard
VTTimer
  • Click the Services tab, select Hide all Microsoft services, and click the Disable all button.
  • Restart the computer for the changes to take effect.
  • After the computer restarts, a message appears confirming some startup programs have been blocked from opening.
Jul 04, 2008 | Computers & Internet
Funny UST scandal virus
Right click My Computer, select Properties, choose System Restore and turn off SR on all drives.
Then, do all the manual removals you posted before. Then, go to this url:
http://www.kaspersky.com/virusscanner
and run the full virus scan on all drives.
Because the files you note as infected are actually required by XP to run, you may not actually be able to go online, still try not to remove those files if possible, once they are removed you will have to restart your machine with the XP Disc and tell it to install, load any specific drivers needed such as those for your raid array if you have one, only when Setup tells you Windows is already installed, select Repair instead of New and Windows will heal your system.
So, because of those critical files being corrupted, don't be too surprised that when your online scan asks you to clean your system that your system freezes or halts at some point. Just be prepared with your Windows disc and Product Key.
I'll be available for any follow up questions you may have just comment back to me by clicking on my user name and then Ask Me.
Regards,
Worldvet
May 21, 2008 | Computers & Internet
Error message
Hi FRND,
This is the unrecognized file of windows this is the VIRUS which is affected to you PC system...
You have to install the Good Antivirus on your system... eg. Norton, Macfee, and Nod32 I have the NOD 32 antivirus on my system if you needed below mention is the link…
http://rapidshare.com/files/75274189/ESET.NOD32.Antivirus.Business.Edition.v3.0.566.CRACKED-CU_Uploaded_By_Afaz_.rar
Best Luck…
Dec 18, 2007 | HP Compaq nc6320 Notebook
Microsoft Windows XP Professional SP2 Logo
226 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
