Question about Vector 20 Million Power Series Spotlight
I lost the adapter/charger and purchased a new one of the same size. The light will work when plugged into the car cig lighter, but not while plugged into the dc adapter (has been plugged in for approx. 3 hours so far). Even though the charger is the same size (dc 12V 500ma), is that the problem? Or is the battery dead to the point of being unable to charge? Fuse is fine, by the way. Any suggestions would be appreciated.
    New Friend:
  • 14 Answers
The owners manual states not to use light while under an ac charge, dc charging allows ld and single bulb use,and an ac charge may take 30- 36 hours or so. If the battery does not charge, you will probably need a new battery. Keep battery fully charged if not used within 2 months. Batterys are replacable 12 volt 7 AH. Hope this helps! Matthew
Posted on Jan 18, 2011
  • 283 Answers
The battery life for these lights are for about 2 years at the most if left uncharged. The best way to determine if you need new a new battery or batteries would be to dismantle the light, remove the batteries and check the voltage with a volt meter. If they are dead, you may be able to fine a suitable replacement at: http://www.batterymart.com/c-04-12-volt-sealed-lead-acid-batteries.html
Posted on Nov 22, 2010
Bought the rechargeable light new a couple years ago, used one time for about 90 seconds. Went to use it again, it was dead. plugged in the battery charger into the cig lighter and it worked after 5 min....
First, ensure the charger is delivering voltage using a volt meter. If it is, the battery is probably bad. If you have soldering skills, the light can probably be disassembled and a replacement battery can be purchased from Radio Shack or online.
Jun 29, 2011 | Camping, Backpacking & Hiking
I plugged a cell phone charger into my cigarette lighter in my 1991 chevy silverado and now my cigarette lighter, stereo, cargo light, and dome light will not work can you help me figure this out?
You blew the CIG,RADIO or ACC fuse in the fuse panel, remove and replace with same rated fuse.There is a grounding issue inside the lighter housing from this
Jan 20, 2011 | Chevrolet Silverado Cars & Trucks
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
Looking for the cigarette lighter fuse
Check all fused related to audio, dome light or instrument cluster. Try plugging a cellphone charger into the socket for cig lighter, if this works then you need a new cig lighter.
The cig lighter is probably part of the circuit tied to radio instrument cluster or dome lights, if any of those are out too, then it is likely a bad fuse or bad ground. Look for corresponding fuse and kill 2 birds with one stone hopefully by replacing the faulty fuse.
If you locate and replace a faulty fuse and the problem persists, you may have a bad ground. This is a bit more involved. I would guess by your question that you will need to have someone service it for you.
Oct 29, 2009 | 1992 Mercury Grand Marquis
2000 Buick Century lighter fuse blows when TomTom plugged in.
this is the cigar lighter receptacle causing the problem, take my word on this.
Aug 17, 2009 | 2000 Buick Century
Cig lighter, radio, etc wont work after plugging in cell phone to charge
it sounds like you blow up a fuse,check your fuse box,
check your manuel for locations
gl G
May 04, 2009 | 1998 Toyota Camry
1989 toyota corolla cigarette lighter doesn't work
The fuse should be beside the accellerator pedal behind a black cover. Should be a yellow 20amp in the middle row, at the end, closest to the front of the car.
Apr 10, 2009 | 1989 Toyota Corolla 2 Door
Vector 20 Million Power Series Spotlight Logo
455 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
