Question about Brother MFC 7420 All-In-One Laser Printer
Paper jams on my brother 7420 - Brother MFC 7420 All-In-One Laser Printer
  • Brother Master
  • 4,338 Answers
Solution depends on where the paper jam occurs. Look under the "Troblshooting " section, chapter 11 page11-7 of the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 12, 2010
  • fathi_effat Dec 29, 2010
    I did all explanation about paper jam on my printer, but still the paper is jammed under its drum and it messages " sliding the blue tap right to left several times " I did that one too. It still error the same message all the time. ( I also snap the blue tap to its home position all the time ). I'm wondering what's wrong with that !
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420. New Brother Toner, New Drum, cleaned feed and separator rollers, changed paper, still jamming. Paper stuck around brown fuser roller. What can I do next?
Check whether the fuser rollers are free turning. If the paper is stopped at the ejection roller, the ejection roller needs to be replaced.
Dec 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 All-In-One troubleshooting
Brother has a free tech help service.Go to their website
Sep 16, 2009 | Brother MFC 7420 All-In-One Laser Printer
My MFC-7420 jams paper after each copy what is the problem.
First you need to clean up the drum and inside the printer.
after that if still jamming paper.
you better check all the rollers and check the drum unit.
if possible, please chang the drum and that should be working fine.
May 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jams 1/2 way through drum/cartridge. Jams like an accordian, with 1/2 page printed. My printer is a Brother mfc 7420. About 2 years old.
Take the toner cartrige out, look around with a flashlight for a piece of paper or something that could jam the works. Check the movable tab that comes out of the front of the machine to hold paper up, maybe it has gotten crooked or something. Don't have anything in front of the machine to block the paper coming out. A can of compressed air can be used to blow the machine out.
Apr 12, 2009 | Brother MFC 7420 All-In-One Laser Printer
MFC 7420 front paper jam
First you need to clean up your printer with duster and after thatn, check the toner and drum to see any paper jam or anything wrong,
Normally after you clean up the machine, should working fine,
if still not working, please replace the rubber roll.
Apr 06, 2009 | Brother MFC-7420 Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc 7420 constant paper jam
need a little more info on this. does the paper look like it catches on something? is there any nicks or anything on the lead edge?
razors
Jan 07, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jamming
tell me where it jams so that i may help you! brother tec
Dec 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 Paper Jam. Paper will feed from tray to Toner/Drum then Jam. Feeds only about 4 inches of the sheet then Jams. I have replaced the toner/drum unit. Any help is appreciated. Thanks.
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Nov 13, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
387 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
