Question about Phil & Teds E3 Jogger
Where can i get a new baket/footwell from? - Phil & Teds E3 Jogger
Groovystyle.co.uk - they cost about 28 pounds inclusive of postage
Posted on Jul 11, 2008
BMW E46 CLIMATE CONTROL UNIT
there could be a problem on the line.. also check the compressor unit, and check for the leak..
Jun 14, 2008 | 2001 BMW 325
2008 highlander sunroof drain goes into the footwell but does not exit and builds up till overflows into passenger side. How do you access the footwell to clear blockage? Hose into the footwell is c
Go under car with a wire and poke upward. Try to pull out as much blockage as possible so it won't happen again. You can make a small bend in wire end to do this. GOOD LUCK FRIEND.
Nov 17, 2014 | 2008 Toyota Highlander
Honda gearbox
that is way too much slack unless the drive chain is slack. hold the drive chain tight and try again. any more than about 10 degrees would be too much
Feb 10, 2014 | Honda CBR 900 RR Fireblade Motorcycles
Wet footwell
need new window seals more than likely they have faded in the sun.
Jan 29, 2013 | Toyota Cars & Trucks
Baket pag binubuksan ung PSP . need ko pa buksan ung UMD case para mapunta sa MENU ?
ganito gawin mo.. tangalin mo muna ung UMD bgo m buksan psp tpos pnta k s setting hnpin m un autoplay ng UMD tpos ioff m..
Jul 19, 2011 | Sony PlayStation Portable (PSP) Slim...
My washer sounds like a turbine engine during spin cycle
It is the bearing in the outter basket. Some of the units had 5 years on the outter baket. I am a service tech & fixed several of these.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Is the flywheel nut reverse thread?
There is a special wrench that will hold the basket while you undo the nut. you should be able to buy this tool at a local dealer pretty cheap.
Mar 28, 2009 | 2003 Yamaha YZ 125
Drivers footwell full of water ( not flood damage )
There are drains under the battery box and under the ECU module. When they plug with dirt, pine needles, whatever, the water fills up the space and backs into the vents or wherever it can leak through the firewall and usually ends up in the rear footwell, drivers side. If you don't get on it and maintain those drain holes, it will start to take out the electrical. Gets very expensive for a simple design flaw. The carpet has to come up and thoroughly dried as well. Not much fun and a lot of work.
Oct 18, 2008 | 2008 Ford Focus SE Sedan
Phil & Teds E3 Jogger Logo
118 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Dorel UK
Dorel UK
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
