Question about Kenmore Washing Machines
Captbarry@frontiernet.netkenmore mod 110 will not spin out... what could be the problem, belt... transmission???
  • Kenmore Master
  • 43,501 Answers
The most common problems would be motor or belt...
If the machine still agitates then it probably is not the belt....
The motor runs one way for the agitation and the other for the spin....
The spin direction of the motor has probably gone bad...
Using a good electrical meter and following the wiring diagram you can check to see if the motor is getting power to it before replacing it...if it is getting power and not running then it needs to be replaced...
heatman101
Posted on Nov 12, 2010
Kenmore 90 series mod 110. 478621 leaking from above the transmission . How to check drum seal. Thanks
Remove the agitator, you need a spanner wrench to remove the nut holding the spin tub down, then it will lift out. You will need a new tub donut seal that fits into the outer washtub, check for corrosion on the support tube, if it is corroded and not smooth, it will likely leak with the new seal.
Apr 23, 2016 | Kenmore Washing Machines
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Washer wont agitate or spin
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Apr 21, 2009 | Maytag Performa PAV3200
Steps to disassemble Maytag washer's transmission mod LAT9704AAE
I had an outside service tech. to repair it . He replaced seals and bearings .
Apr 01, 2009 | Maytag Washing Machines
Kenmore 60 series 110 model wont agitate or spin,hear motor
Likely the drive belt/coupling or transmission has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Mod 110 keep spinning
the holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE 110 -LETS WATER IN..DOES NOT SPIN
Hello Sylvia,
You said,
HELLO...I HAVE A KENMORE 110 WASHER, LETS WATER IN BUT DOES NOT SPIN. PLEASE HELP. SYLVIA
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin.
The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts.
If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed.
As the clutch wears out, it may prevent the unit from spinning well or at all.
If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and draining, the other.
It's possible for a motor to burn out in one direction and continue to operate in the other.
If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool®
have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective,
the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized.
These components allow the inner tub to spin freely inside the outer tub. When this is the problem,
you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety,
washing machines are made so that they spin only with the lid closed.
The lid switch prevents the spinning action when the lid is up."
Bless You,
Please give me a good rating for the sound advice , before you sign off.
Thank You
Sep 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
