Question about Samsung Washing Machines
After completeion of wash and before spin the machine is displating 4E and stopping the process. Water is remaining in the cylinder
    Problem Solver:
  • 5 Answers
This is common on machines that have a faulty water pump. Check the drain hose first to make sure it is not blocked. The water pump drains the machine before it can go to the spin cycle. If you drain the tub by hand and then let it go thru the spin cycle it is likely that your pump is faulty.
Posted on Nov 12, 2010
4e on my samsung front load WF42H5000AW
A 4E code indicates your machine is not sensing that it is filling. The corrective action is to check that water supply is on and has adequate pressure, hoses are not kinked, and that filters on the inside end of the water valve are not clogged.
Nov 21, 2016 | Samsung Washing Machines
My washer gets a 4e message.we have checked the hoses cleaned out meshes.has real good water pressure.it gets the 4e only when it's fixing to wash. if I put it to rinse and spin it will.
Your washer should have a solenoid valve for the cold and hot water. The valves open to allow the water in the drum and will fill the washer according to the load being washed (small, med large, etc.) If the washer does not reach the required level in a measured amount of time, it displays the 4e code. It is possible that one of the solenoids is not completely opening, therefore restricting the flow.
Jul 30, 2015 | Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
Descaling process counts down on the displat but no solution is running through the unit and thr counter stops on 1 min remaining
This is normal behavior, your machine is fine.
For example, the machine says "5 minutes remaining" and then it goes 5:00, 4:59, 4:58....etc all the way down to 4:01.Then it changes to "4 minutes remaining". Which is 4:00, 3:59, 3:58, etc.
So at "1 minute remaining" the machine is really at 1:00, then 0:59, then 0:58 and all the way down to 0:01.So, after the "1 minute remaining" goes away, the machine is actually done cleaning itself.
May 08, 2011 | Miele CVA 4066 Stainless Steel
Ongoing problem with my Samsung j845. First we got 4e messages which I traced back to a worn out solenoid switch at the water intake. Have put a new one in but now the water won't stop! - and a nasty buzz...
I am a repairer.this problem is in the electronic PCB.The inlet valve has spiked the PCB.the PCB now is providing constant power to the valve even when not being told to.You have replaced the valve but now runs water as soon as you switch power on at machine.PCB needs to be changed as well.
May 23, 2010 | Samsung Washing Machines
Washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Feb 23, 2010 | Washing Machines
4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
