Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel line in tank broke off need to know if fuel tank can be taken apart to replace hose and if so how
  • 297 Answers
No the fuel tank is part of the case. The fuel line needs to be pushed through the holes. The supply line goes through the big hole on the left. And the return line goes through the small hole on the right hand side.
It is tricky getting the lines through these holes, It helps to use a small pick or punch to push with, then I use a hemostat to reach inside and pull the lines in. Use bulk line and dont cut it until you are happy with the length. The supply line ( the one with the filter) should extend outside the fuel opening. The return line just need to enter the tank about an inch or two.
Hope this helps
Posted on Nov 13, 2010
Clogged fuel line
John, you can just replace the line or try replacing the fuel filter, while the line is apart at the filter blow on the hose going to the fuel tank to see if the clog is on that side. Use compressed air to blow the clog back into the fuel tank then clean the tank out by siphoning the fuel out or remove the tank and flush it out. If the clog is after the filter remove the hose and blow it out (I would replace it) and remove the bowl from the carburetor and see if there is trash in it. You may need to clean the carb.
Oct 15, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My Poulan 2025 Chainsaw fuel hoses have broke down and fell apart. I have new fuel line but do not know the hose routing. All I found in the tank was pieces of hose and the filter. Only one hole coming out...
Check out epartsreplacement.com and there is a video on there you can watch that talks about fuel line replacement. It is a very helpful video Tom. Good luck
Aug 07, 2011 | Poulan Pro Chain Saw 46cc 20"
Trying to take apart to replace fuel hose.taken screws out and lid offvaccum.but will not come apart why.jerry
Sometimes, its easy to miss a "hidden" screw. The plastic case probably has plastic guides for it they may even interlock together. Search again for a "hidden" screw before giving up. You will find more than just one fuel line. Here is how you would replace them if you choose to do so (recommended).
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Aug 19, 2010 | Poulan Pro Super Blowervacuum
I am replacing the fuel tank assy and purge bulb (i.e. primer) on my Sears Craftsman model 358.798940. The original plastic tubing was old and brittle and broke apart while disassembling, so I could not...
The order of fuel travel should be:
Fuel filter to fuel hose to Carb's Fuel Supply nipple. (On the main body of the carb)
Primer Plate Nipple on carb to fuel hose to Suction Nipple on Primer Bulb. (It must pull fuel thru the carb, not push)
Pressure Nipple on Primer Bulb to fuel hose to Fuel Tank Return hose.
When correctly installed, the fuel will be PRESSED into the fuel tank via the return hose when primer is pressed in . . . and SUCTIONED out of the tank and into the Carburetor when primer in released.
Hope this helps,
Dolf-
Oct 16, 2009 | Garden
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Fuel Line Leak, Need Advice
the metal line is part of the fuel pump. if the line is that fragile it should just be replaced. what if it broke and left you stranded somewhere. the fuel tank might look rusty but it's probably just surface rust.
Jun 25, 2009 | 1999 Buick LeSabre
My homelite weed eater sx-135 the fuel filter broke of the tube
The longest, and sometimes smaller in diameter, fuel line goes from the carb. to the bottom of the tank. It should rest comfortably on the bottom of the tank. The other line should go from the primer bulb to just inside the gas tank, (about an inch).
HINT: Cut the fuel lines at an angle before inserting them into the gas tank. This will allow you to get them in much easier.
If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Leaking Fuel tap (petcock)
This sounds like a vacuum lock pet ****. 3 position? run, prime,and reserve? If you have it on pri, You will fuel running or not. If set on run, then you will only pass fuel when engine is running, and of course res. when tank is used up. Is this leak at the valve? or from the tank or internally flowing? Tis should also be a gravity feed fuel system, please correct me if I'm wrong. good luck. Long fuel lines are not prefered on gravity feed systems.
May 20, 2009 | 1986 Honda VT 500 C Shadow
I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Broken line after fuel pump replacement
All the fuel lines in the modern fuel pump in tank vehicles need the 2-3 lines hooked up, so it would be a good idea to do so. Rick
Apr 13, 2009 | 1999 Ford Explorer
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
101 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
