Question about Kenmore 20172 Top Load Washer
Switch the switch that gets pushed in when you close the lid that turns on the washer came apart. is this something that i can fix myself? is there diagrams of how it should go? jae
    President:
  • 1,314 Answers
Yes facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. then you can acess the lid switch
Posted on Jun 20, 2008
Washer will drain and spin only if lid is open and switch is pressed
Your lid switch has started to come apart so the plunger does not push the switch all the way down. You can either replace the switch or remove the switch and use a zip-strip to close the housing back together.
Aug 12, 2012 | Whirlpool Washing Machines
My washer starts spinning then stops. what can i do to fix it? its a GE s3200y1ww
I have the same washer. For me, the lid switch assembly was bent and was no longer being triggered by the lid strike. To test it, I opened the lid when it stopped spinning, and pushed the switch with a screwdriver and it continued to spin.
To fix it, I repositioned the wire on the switch assembly and elevated it with a piece of plastic that I just taped around it. I didn't have to take anything apart as you can squeeze your fingers in between the parts easy enough. Works now, I just need to redo the tape every 6 months or so as it wears down.
Parts diagram: http://www.us1internet.com/S3200Y1WW_21181425.htm
Sep 28, 2010 | GE WBSR3140DW Top Load Washer
Washer wont run unless i forcefully push the lid when closed
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
It is a simple and relatively inexpensive fix.
Jul 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool - Filled with water to wash and stopped. Pushed in and turned to see if I could get something to happen or reset the cycle. Does nothing at all.
if the washer is full of water and will not continue it needs the lid switch replaced : the lid has to be closed so the washer will agitate and spin the lid switch is under the lid on the right or rear left
Apr 25, 2010 | Whirlpool Washing Machines
Washer lid is not triggering button to make machine work.
First, see the Sears Parts Site for your washer:
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If it works, the Lid Switch is a relatively inexpensive part.
Jan 02, 2010 | Washing Machines
Wont drain or spin
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it useing the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down .if you have to replace the lid switch for it to work properly or bypass the lid switch it needs to be from under the console .do not drop screws in between the tubs
Aug 16, 2009 | Kenmore 24032\24036 Top Load Washer
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
It fills up with but completely stops after it
If your washer fills, agitates, but won't spin out to rinse, this is usually a symptom of a bad lid switch. The switch is usually located on the right hand side of the washer tub opening around the rim where the lid seats. There is also a plastic plunger on the lid that will push down on the switch when closed to make contact. On some models, the lid switch is located on the left hand side of the lid in the rear. It is controlled by an armature on the hinge of the lid closing the switch contacts. Check the switch by opening and closing the lid. If you do not hear a distinctive "clicking" sound of the lid switch, the switch isn't working and/or the plunger may be broken off. If you can provide your exact model number (located under the lid of the washer along the rear rim of the tub opening) I can tell you which type of switch you have and the part number. Let me know if this is helpful. This is a very common problem with this model washer and a simple fix.
Sep 09, 2007 | Kenmore 24632 Top Load Washer
Kenmore elite canyon capacity washer
check out the lid switch ... move it up and down slowing and see if you can hear the lid switch clicking.. lid may not be hitting just right or something... should also be under warranty
Sep 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 20172 Top Load Washer Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
