Question about Lexmark Office Equipment & Supplies
I have a Lexmark x6170 printer. How do I get it to print a fax confirmation page?
  • Lexmark Master
  • 4,338 Answers
See page 71 in the manual. You set it through Advance fax settings
http://www.lexmark.com/publications/pdfs/x6100/eng/ug.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 12, 2010
How to run a report from Lexmark X6170 fax
Please follow these steps to run a report on your Lexmark X6170. From the printer operator panel, press Fax to enter Fax mode > press Options repeatedly until Print Reports is highlighted. From there you can print an activity report, send log, receive log and fax settings list.
I hope this helps.
Nov 07, 2011 | Lexmark X6170 All-In-One InkJet Printer
Connected, but cannot install and print
Thank you for contacting Fixya.
Please install the Lexmark printer on Windows XP using the "Add Printer Wizard" by following the steps given below:
1. Go to "Start," "Control Panel" and "Printers and Faxes."
2. Click on "Add Printer" and then click "Next."
3. Select "Local Printer" and then click "Next."
4. Select the required Port (USB001 Virtual Printer Port if the printer has already been connected) and click "Next."
Note: If the printer has not been connected, select "File."
5. Click the "Have Disk" button.
6. When the "Install From Disk" screen appears, click "Browse."
7. From the "Locate File" screen, in the "Look In" option, select "Drivers."
8. Click "Open" and then click "OK" in the next screen.
9. When the name Lexmark printer is displayed, click "Next."
10. Leave the name as Lexmark printer and choose whether or not you want the printer to be the default.
11. Indicate whether or not you want to print a "Test Page."
Note: This is the "Windows Test Page." It won't be printed before the cartridges are selected.
12. Click on "Finish." The printer files will then start to copy from the CD.
13. Please follow the on-screen instructions to finish installing the printer.
Sincerely,
Jeeth
Apr 12, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X160 doesnt Copy or print faxes
I have been getting a remote fax error often enough that's it's becoming a nuissance. Any suggestions on how to fix this problem?
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 will only copy l/4 of page as a copier but copies full pages from the computer
check the properties and page settings before you print you may find your page settings are incorrect to what you want. Set to all pages, make sure print colour documents black is unckecked, make sure no other settings are telling it to print other than what you want. Post back if no good.
Sep 03, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 random shut off while printing
I think the power saving mode is on your printer ?try setting to off mode or 2 hrs mode...
Mar 13, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170
Received fax is unreadable or blurry
Please go through the checklist below to see if the suggested action(s) can resolve the issue.
* Make sure the copy function is working well.
* Print a Clean nozzle page from the Maintenance menu. If the printout has unexpected white or color horizontal streaks or missing portions, print the Clean nozzle page again. If you are still experiencing streaks or mission portions, you may need to replace your cartridge(s).
* The cartridges may need to be aligned.
* You may need to ask the sender to increase their fax quality.
Sent fax is unreadable or blurry.
1. If the receiving party indicates that the fax output is unreadable or blurry, you may want to try increasing the fax quality.
2. Check the scanner glass for excess amounts of smudges and/or fingerprints. If the scanner glass needs cleaning, moisten a clean, lint-free cloth and gently wipe the scanner glass. Make sure the scanner glass is dry before scanning the next document.
Feb 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
X6170 Prints only one page then freezes
drivers are most likely not up to date, especially if you used the old ones. Gotta go to lexmark, and get the latest Vista friendly driver. I recommend the highest quality one, with the most features(so that Vista won't spit it out again).
Feb 06, 2008 | Lexmark X6170 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
