Question about Ricoh Aficio 1013F Copier
SC 101 Code Malfunction problem - Ricoh Aficio 1013F Copier
    President:
  • 2,072 Answers
That is a failure of the exit sensor.
Posted on Nov 12, 2010
Ricoh 2075 error code sc101
Ricoh MP 2075 SC error 101. Found that the Exposure Lamp would stay on after reaching home position and this fault would appear. Found the solution was to replace the IPU PWB
Apr 22, 2014 | Office Equipment & Supplies
Sc 101
there's a number of lens in the scanner board, can u tell where is that lens is. if it is really the lens misposition check all the screws there could be a loosen one, but usually if lens are place into the unit again once it is pull out for replacement it will automatically place in its original position.
you can try these:
SC-101 for ricoh (complicated to fix)
- exposure lamp defective
- check SIFB
- clean all the sensor in scanner board
- check the Power supply for loose contact
Mar 04, 2013 | Ricoh Office Equipment & Supplies
Functional problem within the Copier. It sowing SC 101
look my friend 101 means that check that scanlamp light in main scan and check mirrors and lamp staplizer is worked
Mar 29, 2011 | Ricoh FT7950 Copier
I have a 2005 s type 2.7 automatic diesal . A restricted performance light come on occasionally. The car has recently just broke down - everything appeared just to shut down . The recovery breakdown guy...
Turbocharger (TC)/supercharger (SC) boost pressure
control B - electrical malfunction
probable cause of it might be
Wiring, TC/SC boost control solenoid
but it could differ from auto maker
Feb 26, 2011 | 2002 Jaguar S-Type
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh Aficio MP 161 giving me an error code of SC670 and SC 980. It stops working all the time and I have to turn it off and back on.
One of the following controllers is
installed to the basic model:
* The controller of the MFP
model
copier/facsimile model
printer/scanner/copier
model
OR
The controller of the optional
printer/scanner is installed to one of
the following models:
* The MFP model
* The copier/facsimile model
* The printer/scanner/copier
Dec 04, 2009 | Ricoh Aficio 450 Copier
Customer has an Sc-405 code. They reset it by turning off machine then on. The machine only works for part of day then go's back into sc-405 code again.
that is a transfer belt error. transfer belt not moving away from the drum during ID sensor pattern check.possible main motor/ drive malfunction, trans. belt position sensor problem.
Nov 05, 2009 | Ricoh Aficio 450 Copier
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
69 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
