Question about Casio G-Shock GW500A-1V Wrist Watch
How do i change the time setting from 24 hour to your average 12
  • 12 Answers
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press adjust again. 12H or 24H will be flashing at the bottome. Use the receive button to cycle the mode. When it's what you want, press adjust.
Posted on Mar 13, 2011
  • 2,334 Answers
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Posted on Nov 16, 2010
5 Suggested Answers
  • 12 Answers
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Posted on Jul 05, 2007
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
escapement
  • 2334 Answers
SOURCE: Changing from 12 hr to 24 hr on a Casio Data Bank 150
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please ...
Posted on Apr 02, 2010
reyjoshua07
  • 1157 Answers
SOURCE: timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 15, 2011
My Watch is showing military time but i want it to show in the 12 hr clock
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 | The Watches
Skemi watch 1068 changing the time from 24 hour time to 12 hour time
On a different Skmei model, you can toggle the 12/24 settings within alarm settings. This also changes the setting for displayed time.
As I suspect that a lot of their models use the same internal module, it's worth a try.
Sep 29, 2017 | The Watches
How do reset a shake n wake to 24 hour time
SHAKE N WAKE: TO CHANGE TO MILITARY TIME
Hit Mode 3 times to set the time
Hit Reset/TimeSet twice to make hours flash
Now keep hitting StartStop/Adjust repeatedly. After you go through 12 hours of AM then 12 hours of PM it will start going through the hours in military time.
Mar 12, 2014 | Maxi Aids Shake n Wake ZZZ Vibrating Alarm...
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Nov 13, 2010 | Timex 1440 Nylon watch
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Mar 10, 2008 | Timex 27191 Wristwatch
Jul 05, 2007 | Timex Fashion Classics 78587 Wrist Watch
Casio G-Shock GW500A-1V Wrist Watch Logo
382 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
