Question about Alpine MRP-M1000 Car Audio Amplifier
Turns on but no bass - Alpine MRP-M1000 Car Audio Amplifier
  • 48 Answers
MAKE SURE FUSES ARE GOOD AND YOUR RCA JACKS ARE GOOD AND CONNECTED,CHECK GAIN LEVEL BRING IT UP HALFWAY AND COSSOVER IS DOWN
Posted on Nov 12, 2010
To much bass and vibration
-5 decibels can be quite loud. Either turn down the bass, volume or both. The bass could be vibrating some items on a shelf or any other place. If you continue to play it that loud, you will more than likely, damage the amp.
Dec 19, 2013 | Audio Players & Recorders
How can u turn up the bass speaker because its really low
you can turn up the bass setting on your radio, or install an amplifier for the bass speakers.
Nov 17, 2013 | Car Audio & Video
How to adjust Dg11100 car amp
If your head unit has an amp gain, turn it up as high as it will go. If it is hooked up to subs, the head unit will say subwoofer output in the menu. Then take a small screwdriver and turn the amp gain on the side of your amp counterclockwise to zero. Turn your freq. up to about a third. Crank your system up, with a song with good bass, and slowly turn your gain up till the bass from the subs sound distorted, and back it back down. If the bass is drowning out the other speakers in your car, then turn the gain down some more. I find it works best if you have your trebble up high, your mid range at a little less than half. And your bass at zero or one. Your amp is cranking up the bass, so let your other speakers handle the rest. This allows it to sound clearly at higher volumes.
Jan 02, 2013 | Cars & Trucks
How do you get the bass remote to work, when i plug it in i still cant control the bass
the remote wire is just to turn the amp on and off. it doesn't really turn the bass up or down.
Aug 10, 2009 | Pyramid PB1281X Car Audio Amplifier
Bass
greetings. Unless the unit has a bass volume control on the sub itself the only way to lower the bass settings is through the built in eq and or dsgx settings (similar to a bass boost)
ryan
good luck and please rate
Feb 14, 2009 | Sony MHC-GX450 CD Shelf System
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Setting low pass and bass eq
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Bass problem
You're getting some sort of capacitor discharge noise on your signal. There's no easy fix for that. It will have to be taken in for service.
Mar 16, 2008 | JVC RV-B90 Boombox
The bass box
Hi Jamesroy,
Remove the Audio inputs from the bass box to see if the thump is coming from the Audio input. Of course do this with everything turned on. What we are trying to figure out is where the thump is originating from. If the bass box does not thump when the audio inputs are disconnected, the thump is coming from somehwere between the bass box and the circuits inside the head unit.
If you still have the thump after the Audio input wires are disconnected, then your bass box's amplifier has noise problem. You might try getting a noise filter from best buy to put on the power supply feeding the bass box.
Nov 30, 2007 | Pioneer DEH-P7400 CD Player
Bass volume
Press the DBB button on the original remote to deactivate the Dynamic Bass Boost
Nov 03, 2007 | Philips FWC527 CD Shelf System
Alpine MRP-M1000 Car Audio Amplifier Logo
307 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
