Question about Breville CBL10 BlendMaster Classic Work Top Blender
I can't unscrew the glass from the base on a breville blr50mr blender
4 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: Lost Seal for Blender
I would suggest you contact the company at
http://www.breville.com.au/ (click on "what's on your mind") and let them know the problem... they should be able to direct you to a UK parts source or help you in some other way.
Posted on Mar 23, 2009
pappapumpdaf
  • 635 Answers
SOURCE: grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Posted on Mar 09, 2010
  • 10865 Answers
SOURCE: I need to acquire a glass jug for a breville BLR-3
Hello. The best route to go is to work directly with the manufacturer. here is their contact info
  • AskUs@BrevilleUSA.com
  • 1.866.BREVILLE (1.866.273.8455)
  • 8a to 5p Pacific Time
  • Posted on Mar 22, 2010
    I have a Breville 800BLXL/B blender that won't power on. When plugged in, the power button will not illuminate.
    Most likely its the large yellow capacitor on the main circuit board. I've had this fail on my Breville coffee machine and blender.The coffee machine was a 1.5uf capicitor nd the blender 1.0uf.rated at 275vac. what happens is over the years of power spikes and surges etc the capacitor breaks down to a lesser value than its original "capacity. ie 1uf down to 0.3uf it provides enough power to drive the display electronics But not enough to power the relay to turn the motor on.
    . there are 3 screws under the label. Peel off the label . remove the 3 screw. remove the fan cover.
    to remove the fan . hold on to the blender jar mounting drive and unscrew the fan. a small square nut is what holds the fan on. remove the rubber feet an the 4 star screws under the rubber feet.
    you can then remove the base.
    Most likely the fuse is OK. However I've found ( in repairing mine) the big yellow capacitor 1uf 275vac is at fault. over time and power surges it breaks down and cannot pass enough "power:" for the power supply to call the relay to turn on the motor. You van get a new capacitor from Jaycar ( aus or NZ ) for about $6.00 . unsolder the capacitor and solder a new one in. reassembly is reverse. Just be careful not to trap the micro swicth wires ( black) under the motor surround.
    Jan 21, 2017 | Breville Blenders
    Krups blender switch lights, but motor doesn't turn
    Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
    kolbrun
    Mar 14, 2014 | Krups KB790 Blender
    Hello. I need two parts for my Breville Classic BlendMaster Model CBL-10. I need the removable centrally located inner lid and also the blade assembly features patented stainless steel twin cutting...
    Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
    Jan 23, 2011 | Breville CBL10 BlendMaster Classic Work...
    My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
    If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
    Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
    I need to acquire a glass jug for a breville BLR-3 Blender. Any suggestions would be appreciated !! Thanks
  • Mar 22, 2010 | Breville CBL10 BlendMaster Classic Work...
    Grease build up around blade and where it attaches to base
    Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
    I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
    Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
    Dec 23, 2009 | Waring Blenders
    Broken glass jug on kitchenaid blender model 5ksb2aer4
    Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
    The left hand thread ensures the blade assembly does not unscrew during normal blender use.
    Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
    Grip the wing nut with your other hand and unscrew it CLOCKWISE.
    Remove the wing nut. You can now remove the blade from the plastic base.
    Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
    Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
    Do not over tighten the wing nut; you may have to replace your jug again at some point.
    Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
    Any idea where we can get a new jug for a breville blender?
    This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
    http://www.brevilleusa.com/home.do
    Jan 11, 2009 | Blenders
    Breville CBL10 BlendMaster Classic Work Top Blender Logo
    Top Breville Blenders Experts
    Mike
    Joseph Hoffmann
    Are you a Breville Blender Expert? Answer questions, earn points and help others
