Question about Umax Office Equipment & Supplies
I have a Umax Mirage 11 that has worked perfectly up until now. Just recently though the LED lights that signal that the scanner is ready to scan have stayed blinking continually instead of becoming steady after around 30 seconds.This means that the scanner is not recognized by the computer as a scanner ready to scan. Please advise, I can't afford a new scanner that scans with this kind of quality and I'd love to be able to get this up and running again... Thanks Peter
  • 3 more comments
  • Peter Stallard Nov 14, 2010
    I have tried the advice offered but unfortunately this does not work....Unless the scanner actually starts properly I cannot see how drivers come into the equation as the computer is just waiting for this startup process to finish.I should have mentioned that I have a Mac and I usually go back to an OS 9 or Tiger on my old computer to use the scanner.In the past it has always worked just fine in either.
    For your information I have the original software and Silverfast reinstalled for drivers.
    Please advise...if I really need to pay more I'll do whatever it takes to sort this problem out.
    Thanks
    I should have mentioned that normally use my old Mac G4 for scanning.I have already reinstalled the original Umax software as well as reinstalling Silverfast.I had a choice of using either Mac OS 9 or Tiger for scanning purposes.I have not had any problems before now.
    I have tried disconnecting the scanner from the computer but obviously when I power up the device I still have the startup problem with the blinking lights so the scanner will not proceed with it's own problem detection until it is properly powered.
    Thanks again for the advice.
  • Peter Stallard Nov 16, 2010
    My Umax Mirage 11 scanner will not complete startup so my computer will not recognize it.The three amber lights just continue to blink past the usual 30 seconds.
    I have the correct drivers installed and I am also using Silverfast. Normally this arrangement works perfectly.I tried disconnecting everything and rebooting the scanner while it is not connected to the monitor but it still fails to start properly.
    I am using my second computer with Mac OS 9 and also Tiger which was compatible with my scanner setup.
    Please advise....If I need to pay more for this service I will be happy to do so. I am desperate to solve this problem as this is a great scanner and purchasing another one as good as this is just not an option right now.
    Thanks
  • Peter Stallard Dec 09, 2010
    I have a Umax Mirage 11 scanner.It will not complete startup, it has three continually blinking lights that should remain steady after around 30 seconds.The power cable is OK as far as I can tell.If it was not I feel sure that there would not even be sufficient power to move the light tray normally as it does now.
    It is not attached to the computer because I know the driver is definitely not the problem.If the scanner does not complete startup even if the computer were connected it would not recognize that the scanner was there.
    Please advise.The previous comments did not help although I appreciated the input.
  • Peter Stallard Dec 15, 2010
    The power adapter is exactly the one intended for the scanner and has never been changed.The scanner has been tried on two computers one with the old OS version and the other with the new latest OS version.
    Genius:
  • 1,456 Answers
Hello
It sounds to me that you have a power problem!
Make sure your scanners power adaptor is working properly!
And that the one you are using really is meant for your scanner!
Check Volts and Amps on it! It´s not normal that the lights on it´s flickers!
If all these are in place then the Umax is not compatible with THAT OS version.
Posted on Dec 15, 2010
  • 656 Answers
It sounds to me that you have a power problem! Make sure your scanners power adaptor is working properly! And that the one you are using really is meant for your scan er! Check Volts and Amps on it! It´s not normal that the lights on it´s flickers!I hope it helps
Posted on Nov 22, 2010
  • 2,973 Answers
Peter,
Do not worry. We will make this scanner work again like new.
Follow the link below to uninstall, reboot and reinstall after disconnecting the scanner from the pc/laptop.
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Nov 12, 2010
FS330 Filmscanner - will not light up, or start - no instructions
  • Autocome cdp pro supply correct information of your car problem
    The scanner uses an LED, or Cold Cathode Lamp to light up the negatives. Two or three mirrors then reflect the image through different filters and lenses until it reaches the CCD (Charged Coupled Device). Some scanners, such as Canon's Canoscan, use infrared light so the connecting software can easily identify and remove dust before the negative is scanned onto the computer.
The Information is Collected
  • Finally, the CCD collects the information and converts it into electronic signals on the computer. The resulting scan is either a simple image ready to be edited, or it can be a slightly compressed image that the scanning software has enhanced.
Apr 27, 2012 | Cars & Trucks
I have umax 4700 scanner. When I tried to scan something it shows "scanner lamp has not warm up yet" & keep counting upto 30 seconds. It will take 4 to five time this exercise than it's ready...
hi rakyansfi,
Is that scanner old?because lamp has its own life span.
it cannot scan if the lamp is insufficient power or light.
regards,
mastergani
Dec 30, 2010 | Umax Astra 6700 Flatbed Scanner
Is a Windows Vista driver available for Mirage II?
apparently no,but you can download the driver from here:
http://www.umax.com/download/index.jsp
let me know if it's working
Jul 07, 2009 | Umax Mirage II Flatbed Scanner
Umax Mirage II Flatbed scanner,3 flashing lights
Could be a SCSI termination issue. Try changing the SCSI address number on the scanner to a different one and make sure the chain is terminated properly. If there are multiple SCSI devices in the chain, disconnect all the others until you are sure the scanner is working then slowly add the other devices to the chain making sure everything works as each device is added. SCSI voodoo!
Jun 26, 2009 | Office Equipment & Supplies
My Umax Astra 1220U Flatbed Scanner will scan but the image comes out with a dark "haze" so as to barely read the document. What I am scanning is on white paper with black lettering. Can you help?
It probably needs cleaning. I had a streaking problem with my UMAX 1220 and followed the instructions on this website
http://www.willshak.com/scanner/
Remember to disconnect from the electricity supply!!!
The job is not too difficult and it restored my scanner perfectly.
Mar 17, 2009 | Umax Astra 1220U Flatbed Scanner
Scans the picture wrong
Try setting the scanner software to its best quality settings
Jan 20, 2009 | Apple UMAX Astra 3400 Flatbed Scanner
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
UMAX Mirage II Scanner
I have this scanner.... I had to take the scanner apart(take the cover off) very simple to do. This is a very simple fix. Obvious fix. You will see when you open it where the switch is. Mine was not making contact. You might be stuck with it in the on position once you fix it.
Mar 21, 2008 | Umax Mirage II Flatbed Scanner
UMAX Mirage IIse Running on MAC OS
I had the same problem. I turned off the scanner and unplugged the transparency unit from the back of the scanner and restarted and it is working fine now. Hopefully this works for you as well.
Sep 22, 2007 | Umax Mirage II Flatbed Scanner
Umax powerlook 3000
The UMAX web site appears to have a fairly good knowledge base, especially when it comes to troubleshooting blinking lights. http://umax.com/support/knowledge/index.jsp Doing a search for lights under Support info result a few articles, including this one: http://umax.com/support/knowledge/search.jsp?docs=SC00322
Sep 14, 2006 | Umax PowerLook 3000 Pro Flatbed Scanner
49 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
