Question about Texas Instruments TI-89 Calculator
My "x" is stored as
  • Texas Instru... Master
  • 8,016 Answers
In Home screen, from the command line, use keyboard to enter the NewProb command and run it.
Alternatively, from Home screen press [2nd][F1] to activate [F6: CleanUp]. Select 1:Clear a-z or 2:NewProb
Posted on Nov 14, 2010
I am trying to get the answer to an indefinite integral. I keep getting "argument error" For example, I type in after the integral sign: (sin(x),x) and get the error message. Help!
You already have something stored with the name x. Either get rid of it or use a different name for the variable of integration.
You can see what variables you have stored by pressing 2ND [VAR-LINK] (the minus key).
Feb 02, 2011 | Texas Instruments TI-89 Calculator
I tried using store function but a pop-up states: "Variable or flash application is locked, protected, or archived." what do i need to do to fix it?
You may be trying to store the function in a folder that already contains that function or name. Its called Error Folder, and you will get the errors you mentioned. Try copying the function under the same name to another folder. Go to the other folder, the one you just copied your function too and, rename the function something you don't think will conflict with the original folder. Simply store your function with the new name in the original folder. That should work, and hopefully you won't get any errors.
Dec 21, 2010 | Texas Instruments TI-89 Calculator
I just got the TI-Nspire. I'd like to solve a problem with undefined variables using Negative Exponent and things like the Expanded Power Rule. The Nspire will not let me store "x" as a variable. How...
You need the TINspire CAS (Computer Algebra System) to do symbolic manipulations. The Blue TINspire (with TI 84 keyboard) can only perform numerical computations.
If you use variables, the calculator will assign the numerical value stored in the variable.
Aug 17, 2010 | Texas Instruments TI-Nspire Graphic...
How do I tell if my Power Steering pump is Variable assist or not
I would take the bad hose off and also write down any model numbers off of the pump and take them to my local parts store. Also take along the entire serial number off of your car. They can probably use this info to tell you what type of pump you have and what part you need.
Nov 12, 2009 | 1995 Oldsmobile Cutlass Supreme
Transmission belt came off the pulley how do i get it back on?
Remove the shifter knob, 2 screws and wire for safety switch from the center plate on the tractor. This will give you access to the variable speed pulley and limited access to the transmission pulley. Reach in under the seat area toward the transmission and "feel" for the pulley, slip the new belt on there first but check to make sure you are inside any belt guards. Next you want to get the belt on the top groove of the variable speed pulley (you may need to remove the belt guide or POSSIBLY bend it just far enough to get the belt on then bend it back in place. Lastly, you need to get the back side of the belt against the flat surface on the tensioner pulley in between the transmission and variable speed pulleys. This is a very stout spring and takes some effort to do but I lift up on the edge of the belt with one hand just enough to clear it and pull the tensioner pulley over with the other hand.
You can Google " MTD 13al675g062 " without the quote marks and it will give you a pretty clear picture of it
Sep 13, 2009 | Garden
After doing this division "7/4" I get the answer "1.75". I want to keep the whole number in one variable and the decimal part in another variable. What kind of program I could use to do that? Million of...
You may be able to find a program online that will automatically do what you want however if you don't have to do this too often you can just manually set "1" to a variable via the "STO-->" button (right above the "on" button-- select the value, pres sto-->, alpha and whatever variable you want) and set the ".75" to a variable.
Finding a program may be difficult for this type of program because you're trying to separate a whole number (essentially looking for a whole number and the remainder). You could always write a program for yourself but as I said before it might be a bit difficult.
Jun 25, 2009 | Texas Instruments TI-84 Plus Calculator
Hi to use "STO"
Hello
You can store values in A, B,C, D, and M.
If you do not like the result recalled from a particular memory, Store the correct value in it. To clear the memories (default) store 0 in each of them.
Hope it helps.
May 09, 2009 | Casio FX-115ES Scientific Calculator
HOW TO PROGRAM ARITHMETIC ALGORITHM( ADDITION)IN C++
above int main () you will want "using namespace std;" without quotes. Under that, "int main ()" without quotes, then a [ bracket to start the main function.
Please rate, thanks!
Mar 16, 2009 | Computers & Internet
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Saving what I typed
Depends on what you are trying to save... you can save a variables(numbers) as a "stored value"(store and recall button [STO> and shift RCL>]).
You can bring back what you just typed in (without retyping it all) by hitting 2nd(or shift) enter.
Nov 16, 2007 | Texas Instruments TI-85 Calculator
Texas Instruments TI-89 Calculator Logo
51 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
