Question about Mordaunt Short 309W Subwoofer
Hi my name is Ben. I have a Mordaunt Short home theatre system which is probably 6 yo but has had very little use. On standby mode, the 309W sub started to make a buzzing sound with intermittent louder noises and smelled like it was burning. I unplugged it and haven't used it since. What could the problem be? Is it likely to be terminal or can it be repaired? Thanks so much!
    Guru:
  • 2,178 Answers
It can be repaired. A transistor shorted and possibly some resistors burned open as well. This is due to an overload causing the transistor to drive hard creating heat and eventually shorting out. The transistor needs to be isolated, removed, and replaced as well as the resistors.
Posted on Nov 12, 2010
Testimonial: "Thank you very much I will follow you advice through. Your quick response is very much appreciated!"
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line: http://www.manualslib.com/manual/105794/Mordaunt-Short-Ms909w.html?page=7#manual
  4. READ THE MANUAL
Nov 12, 2013 | Mordaunt Short Aviano 7 - Powered...
Hi i am trying to find out what ampage the glass amps are thats needed for my sub
Are you talking about the fuses.....if you remove the cover on the sub..you can pop out the fuse and look at the end caps on the fuse...the amperage rating should be stamped right on the end cap...make sure you read the type lettering also...the type rating determines if it is a slow blow type or fast acting type...slow blow fuses are usually type "MDL" or "T" and regular ones "AGC" of "F"
Jun 11, 2011 | Mordaunt Short 309W Subwoofer
309i sub not working
hi ,
2 things to do
1 - the power amp has fail and will need to be looked at
2- your amp could have a sub output faillure
Jul 14, 2010 | Mordaunt Short 309W Subwoofer
T2.5amp fuse keeps blowing
the fuse keeps blowing because the amp or power supply is blown up. It needs to go in for service. Pro Line Music 215-736-8055
Dec 11, 2009 | Mordaunt Short 309W Subwoofer
My Sub has stopped working the LED light does turn green but no output comes out of the sub...... any ideas ?
Check that the connection to both the amp and sub are in place and that the wire is not comprimised. Otherwise, have you changed the settings on your amp lately? It could simply be a matter of adjusting settings. If in doubt, start from the start and treat it as a piece of new equipment - set it up from the beginning and follow all steps from the manual.
Aug 23, 2008 | Mordaunt Short 309W Subwoofer
Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Mar 15, 2008 | Philips LX3600D System
Phillips LX3600 Home Theatre
Power up the set and open tray in DVD mode.
Press <9999> follow by <X> buttons on the Remote control.
where x = numeric 1 to 6 denoting the regions below:
Then show your region on TV
1 = USA
2 = Europe
3 = Asia Pacific
4 = Australia, New Zealand, Latam
5 = Russia, India
6 = China
0 = Code Free
This is taken from the original service manual for the reciever
Jan 27, 2008 | Philips LX3600D System
Speakers Crackling and system keeps going to standby.
It sounds like you may have a problem with the sound pc board. If the system shuts down or goes into a stand by mode, then it means the system is detecting an internal problem and is shutting itself down to avoid any further damage. You may need to have it serviced but that could be a little expensive. You can always buy a used replacement receiver if the speakers and sub is still working good.
Hope that helps.
Dec 31, 2007 | Sony DAV-BC150 System
Mordaunt Short Avant 309i subwoofer set-up
Lots of ways. To set it up properly you will need a decibel meter, Radio Shack makes a nice one. With the meter volume can easily be set as well as phase. I'm assuming frequency is the crossover frequency, generally set at 80Hz. This one involves some trial and error as I am not familiar with your speakers. Don't know much about the notch filter. A good resource for setting up subs can be found at: http://www.hometheatershack.com/forums/bfd-rew-forum/index3.html
Jun 18, 2007 | Mordaunt Short 309W Subwoofer
No Power - LED not lit.
Open up the back of your gale 3080 and check the 2 fuses situated near the transformer.They look like 2 silver cylindrical shapes.Check that they have not blown if they have the will cost you around £2 to replace.Better than the 50 quid you will pay when you take it to your hi fi dealer to open up the back of it.
Aug 12, 2006 | Mordaunt Short 309W Subwoofer
Mordaunt Short 309W Subwoofer Logo
925 people viewed this question
Top Mordaunt Short Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
rhodesworks
Are you a Mordaunt Short Audio Player and Recorder Expert? Answer questions, earn points and help others
