Question about Toshiba Computers & Internet
I tried to restore factory settings on my Toshiba Saetellite L500D and it will not configure. Kept trying to configure - got to first screen where it asks you to press enter to commence system set up and then just shut down. now it wont even turn on at all. i press the button and the green light flashes and then nothing, what can I do?
    Guru:
  • 610 Answers
Try to do a complete power drain by doing the following:
1.Remove the power cable.
2.Remove the battery.
3.Press and hold the power button for at least 10-15 sec to drain all remaining power stored in the board.
After this, try plugging the power cable without the battery and turn on the computer. Check if the computer will respond. Put the battery back.
Posted on Nov 12, 2010
Installed factory default system for Toshiba Satellite L500D
If you did not fill in a password during setup you may need to leave the password field blank. I would try that first of all.
Mar 17, 2014 | Computers & Internet
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
Trying to factory restore my toshiba satellite with no luck, i have tried everything that i have read. while pressing F8 there is no option for factory restore. every option on my screen i selected with...
why you not try to select last known good configuration. it will fix your blue screen error. it is may be a registry error or driver configuration error,but if you can fix disk errors with chkdsk command after select safe mode with command line.
chkdsk c: /f
Sep 18, 2017 | Toshiba Satellite M45-S165 Notebook
Blue screen
You can try a system restore before this happened, if no improvement! I recommend a full recovery of your operational system to factory setting.
Mar 18, 2012 | Toshiba Portege M400 Notebook
HOW TO RESTORE FACTORY DEFAULT SETTING MY TOSHIBA SATELLITE L670D WINDOWS 7, KINDLY HELP ME, I TRY USING RECOVERY DISC BUT IT NOT WORK.
If my answer has helped you today please offer four thumbs up as thanks!
Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
Sep 02, 2011 | Toshiba Satellite L670DST2N01 Laptop
Cant restore to factory settings tried 0,f1 and f8 none work
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba A205-S5880 will not boot up. Turned complter on and it goes to safe mode but unable to get to - restore factory settings Windows 7 installed.
On startup try pressing F8 repeatedly. Try last known good configuration from there. If that doesnt work, let the computer go to safe mode, then select the start orb and search "system restore". Go through the on-screen instructions to restore your computer to an earlier point. If all this is still unsuccessful you might want to take the computer into your local computer repair shop. (It may be hardware i.e. hard drive)
May 03, 2011 | Computers & Internet
I want to restore my toshiba satellite 5205-s503 to factory settings. please help. i tried the whole pressing f8 repeatedly thing and there are no options to restore the computer to factory settings.
You will need the restore cds that came with your laptop. Insert the restore cd in your dvd drive and restart your computer. When the message "Press any key to boot from cd" press enter.
Then follow the on screen instructions to restore your computer.
Regards,
nicolasiac
Feb 12, 2010 | Toshiba Satellite 5205-S503 Notebook
Computers & Internet Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
