Question about Mitsubishi WS-55859 55" Rear Projection Television
Timer light flashing
Green timer light flashes constantly and tv wont turn on looked at DM board and it looks fine no bloded capacitors or any burn outs please help
  • Mitsubishi Master
  • 8,617 Answers
The capacitors wont always show any outward signs of being bad. But it the LED blinks constantly without stopping thats telling you the DM isnt completeing the boot sequence. So most likely the capacitors are bad. But dont put the same ratings back. go with 1000ufs @25V but make certain they are the 105 degree celcius capacitors. If you need further assistance let me know
Posted on Jun 17, 2008
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Have ws65869 tv
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16volt.
Jul 25, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Flashig light and tv wont turn on .
The DM isnt completeing the boot sequence when its flashing, later it completed the boot sequence. It sounds like a mitsubishi with bad DM capacitors
Apr 21, 2009 | Televison & Video
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
TV Won't Power on Green Flashing Timer Light
The green power light is continually flashing and the tv will not turn on. I hit the reset button and nothing happened. I have exhausted all other troubleshooting methods. Please help, what should I do?
Feb 08, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
165 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
