Question about Samsung WF448AAP Front Load Washer
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of normal but it chimes again to check the filter. Once again I drained the water and there was plenty of it. For some reason the water is not draining. Can someone please help!!!!
    Problem Solver:
  • 5 Answers
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Posted on Nov 12, 2010
Washer begins filling in short bursts for a few seconds and then stops and does nothing.
The unit has probably not drained and sensors are telling it not to add water. On the front of the machine is a door near the bottom that you remove and you can see the filter cap behind that door. If you remove that you can clean the filter. However, you will get lots of water all over the floor. So be ready with a vacuum cleaner that can handle water.
Sep 25, 2015 | Samsung WF448AAP Front Load Washer
WILL NOT DRAIN
Check the drain pump and drain filter. It is on a small compartment on the front bottom of the washer.
Jan 12, 2014 | Samsung WF448AAP Front Load Washer
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Washer is not draining. I have checked the pump filter & when I drain the water, then the machine will start once again; however when water comes back in, then I have to drain it again. I have only...
I have the same problem with the WF448AAP--I have cleaned out everything, run several cycles with a AFFRESH tablet--that seemed to help a little. Residue (white) has been found in the filter--cleaned it out as best I can. Still have the problem.
Does anyone have a solution?
Jun 05, 2011 | Samsung WF338AAB 4.0 cu. ft. Front Load...
I have a Samsung WF448AAP/XAA washer. I have had it for a year + and have never cleaned the filter on the bottom of the machine. Tech support told me to clean the filter. Dumb, I know, I just didn't...
There is most likely something stuck in the rubber hose between the drum and the pump, Unfortunately this is not easy to get to as it requires tilting the machine back and climbing underneath to remove the hose and check it. Make sure you disconnect the power before doing this.
May 08, 2017 | Samsung WF448AAP Front Load Washer
Samsung washing machine gives Low Water pressure error message and interrupts cycle. Checked inlet filters. Sometimes gives leak/flood warning message. How can I turn off these messages?
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Dec 29, 2009 | Samsung WF448AAP Front Load Washer
I get an F21 error reading on my Duet washer. Which means it has a drain problem. But when I turned it to rinse/drain to get the water out of the clothes, it spins and drains just fine. I am wondering...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. Door locked? Press "end of cycle" for 3 seconds, wait for 2 minutes & try the door. F-21 filter blocked.
How abt a nice rating for the free help? Thnks
Dec 15, 2009 | Whirlpool GHW9400 Duet Washer
My GE front loading washer will not drain the water
Try cleaning the filter, too.  The bottom front panel on your washer should come off by removing 3 screws.  We found a bunch of junk (it was full of lint, change, and other gross stuff).  Make sure to check back up in the hose if you can, too.  Our filter was so full, the lint and junk was backing up into the hose.  That worked for us and saved us a service call.  Hope this helps.  There is another problem, similar to yours, posted on this website with a lot more information and a bunch of testimonials (mine included).  You might want to search for that one to get more info.
Oct 05, 2007 | GE WSXH208A Front Load Washer
Kenmore Elite Frontload washer
Dea, F02 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. See if the washer comes back to life...Catriver..post back
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Samsung WF448AAP Front Load Washer Logo
540 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
