Printer shuts down during middle of printing
I have an HP Deskjet F4180 and it shuts off during print jobs. Sometimes it turns off even without having a print job in the queue. I spent an hour with an HP help desk person checking outlets and finally they sent me a new power cord. Still shuts off. This happened after I installed new ink cartridges, but I have checked them and put them in again in case something was mis-aligned. What next?
  • Office Equip... Master
  • 824 Answers
The power supply within the printer is shutting down probably due to detecting an overheat issue (make sure the vents at the side of the machine are clear of files and folders etc) If still shutting down the a new power supply will be needed. Have a look at HP.parsurfer site with your CB number at hand (on a label somewhere on the printer). I just tried the site but was locking up (surprise). You may be able to get a part number but as with most deskjets you can't get much and usually ends up with throwing away the printer. Good luck.
Posted on Aug 07, 2017
  • 188 Answers
SOURCE: i have got a hp
what you need to do is go the the control panel, performance and maintenance, administrative tools, then double click on "services".
scroll down the list to " print spooler. single click on it to highlight, then on the left click "stop"
once it is stopped, again on the left, click start.
This should clear out any print documents that became "stuck" in the print queue.
Posted on Oct 11, 2008
  • 419 Answers
SOURCE: printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
Control Panel
Administrative Tools
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
Posted on Jan 25, 2009
  • 1996 Answers
SOURCE: My HP 5550 Deskjet printer
Please go the this link at the HP online support site and follow the instructions given for your error lights to adjust the printer clutch.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 29, 2009
  • 72 Answers
SOURCE: Won't print, job remain in queueey
check the data cable or change the usb port if this fail please try to change the cable
Posted on Jan 03, 2010
SOURCE: hp laserjet p1006 printing jobs gets struck in printing queue
Solved a similar problem by turning off the UAC (User Account Control) in Windows Vista and Windows 7 machines. Worked great without UAC on.
Posted on Apr 17, 2010
Printer says Ready, jobs in print que...will not print
open the print jobs and cancel all pending jobs then try to print something and see if it works
Please leave feedback for me if this helped
Feb 23, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
My HP PRINTER,DESKJET F4180 is printing faintly even though there is a lot of ink
I presume that you have tried with different cartridges to rule out the possibility of cartridge fault and you are not printing in draft mode.
Clean the electrical contacts on the cartirdges and carriage.
The steel rod, on which the carriage moves, is set too far away from the paper. Open the printer's top cover and loosen the lock screw of the brackets holding the rod by its ends. Rotate these brackets a few degrees to lower the print carriage towards the paper to obtain desired printing. The screws to tightened.
Feb 17, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
It says E in the small display screen it has and
Turn the printer off.
Disconnect the AC power.
Reconnect the AC power.
Turn the printer on.
Start the HP Support Tool software on your computer, and check the ink-levels on the printer -- no ink means no printing.
Do the lights blink in a specific, repeating, pattern?
Have you looked at and entered your model-number, and looked at the "common trouble-shooting" suggestions?
Apr 23, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Print job stops in the middle of a print job
first if its happening from few days than go for system restore - start - all programs - accessories - system tools - system restore.. select that date on which it worked fine.. or else add printer and install deskjet 990c and than try
Oct 14, 2009 | HP DeskJet 722c InkJet Printer
Printer connected to computer and all is well but when i click on print it tells me that the document needed to be printed is pending and it just never gets printed
You probably have a print job stuck in the queue. Open Control Panel, then Printers and Faxes. Right click on your printer and click OPEN. Highlight the top entry and open Document menu and choose Cancel. You may need to turn off printer and then unplug it for 15 seconds to clear any faults in printer memory. Plug back in, turn on, then try.
Aug 31, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
I have a HP Deskjet F4180 AIO. It is printing
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
May 08, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
I have got a hp deskjet f4180 all in one printer. sometimes it will not let me deleting a printing job in a queue. it keeps saying deleting but it doesnt dissapear also this then stops me from printing...
Oct 11, 2008 | HP Office Equipment & Supplies
HP F4180 Printer not printing in correct colors.
HP recommends that you follow the above link to proceed with the troubleshooting of your problem.
If this doesn't help, please let me know!
Sep 04, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Mar 20, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Hp deskjet f4180 all in one
i have a hp deskjet f4185 all in one printer but i lost the cd. i need the sofware or it will not connect to print or scan please help me where can i get the sofware?
Feb 15, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
144 people viewed this question
