Question about Norelco T770 Beard Trimmer
How open trimmer philips T770 for replace battery?
4 Suggested Answers
hmosoff
SOURCE: I have a Norelco Accuvac T770 trimmer that will not hold a charge
I did everything possible to find help as I did not accept the answer from Norelco. They told me that there is no way to change the battery except by a qualified repair shop. I made them admit that they basically made a consumable device so they can get you to buy new shavers in the future - in so many words.
I finally pried the thing open as carefully as I could. Once opened, you will find 2 batteries glued together. They are Ni-Cd 2,4 volt - 600 mAh batteries. Looking all over, the only store that helped me was Battery Plus. There are stores all over the country storeloc
.aspx">http://www.batteriesplus.com/t-storeloc.aspx .
They sold me two 1.2v 1000mAh batteries for $3.50 each. For another $5 they spot welded them together with tabs for soldering the 2 wires on.
Okay, after getting the new batteries, I went back to my old batteries and slowly pried the tabs of the top. They pretty much snap off as they are only slightly tap welded on.
I then took out my model soldering gun and with a little patience, soldered the two wires on to the new leads on the new batteries.
Within minutes, I had the thing put back together and charging. It works great and now I can tell all of those who said it can't be done - or those who wanted $40 to refurbish it, to go scratch - I GOT MY SHAVER BACK!!!!
We all need to learn to stop living in a consumable world. I have a feeling due to the economy we are facing, we will all try to save money in this manner.
Good Luck!!!
Posted on Dec 30, 2008
SOURCE: NEED TO KNOW HOW TO
Go to Wal-Mart Electronics dept. and buy a DR9576 Digital Camera battery pack for $14.00, then pry at the seam between the front and back parts of the razor after removing the trim head, dust collector cup, and beard rake assembly from the top of the trimmer and separate the two halfs of the razor. This should allow you to easily remove the battery holder-circuit board-charger plug assembly and pull outthe battery pack which consists of two NiCad batteries which are glued together so as to have opposite polarities next to each other. Carefully using a flat blade jewelers screwdriver, pry the metal tabs off of each end of the batteries and take the DR9576 battery pack which is already joined together in the same configuration and place the flat bar tab onto the end of the pack. Hold the battery holder with the wired side of it facing down, and carefully insert the end of the battery pack you just set the bar style tab onto in the end that has the charging plug closest to it so as to have the plastic "springs"
holding the metal shorting tab {flat bar tab} up against the battery pack. When you do this, be sure to align the battery pack so as to have the other end positive terminal lined up with the red wire with the metal tab on it. As you insert this end of the battery pack into the holder, insert the metal tabs with the wires on them in between the batteries and the plastic holder so that they are pinched up against the ends of the batteries. If you did this right and didn't let the tabs fall out of place, you now have replaced the old batteries with a pack with almost twice the storage capacity as the originals had. Reassemble the razor in the reverse order that you took it apart in and plug the charger into the razor for approximately 36 hours for the initial charge. Also these batteries are NiMH which do not suffer from battery memory which means that they do not have to be nearly dead before they can be recharged in the future. your trimmer should now be fully functioning after complete charge for the first time and should give you years more service while holding the charge for in incredibly long time. Congratulations!!!
Posted on Jun 19, 2011
How do i replace my philips beard trimmer battery?
It depends on what model you have. For Example, this is how you replace the battery on a Philips QG3020 beard trimmer:
Philips QG3020 Disassembly Change Battery
You can write here your trimmer model, in order to get instructions for that.
Jan 29, 2015 | Philips Health & Beauty
I have an T770 beard & mustache trimmer, which has
It sounds like the battery is dead and needs replaced. Replacement battery type can be found on shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Sep 30, 2014 | Health & Beauty
NEED TO KNOW HOW TO OPEN NORELCO T770 ACCUVAC TO REPLACE BATTERIES
Mar 20, 2011 | Norelco T770 Beard Trimmer
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
I just got done doing the same thing
Can the charger charge your NiMH batteries? I was thinking of doing the same thing, but didn't think the NiCd charger would be able to charge the NiMH.
I finally pried the thing open as carefully as I could. Once opened, you will find 2 batteries glued together. They are Ni-Cd 2,4 volt - 600 mAh batteries. Looking all over, the only store that helped me was Battery Plus. There are stores all over the country storeloc.aspx">http://www.batteriesplus.com/t-storeloc.aspx .
Good Luck!!!
Dec 15, 2008 | Norelco T770 Beard Trimmer
Norelco T770 Beard Trimmer Logo
745 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
