Question about Zoom H4 Handy Recorder
Distortion when recording flute on cubase
I'm getting distortion when recording my flute, if I lower the gain it won't improve, it happens when I play the higher notes.
I'm using a macbook air and I did all the steps.
What should I do?
And also, can I monitor the recording through the computer?
Thanks,
Pau
    Problem Solver:
  • 8 Answers
K, 1st of all... Try listening to the files directly from the h4, before download to the nbook. No dist? Problem solved.
Otherwise, note the mics are really sensitive, even in low gain, any "wind" instrument, like your flute, my clarinet, or even the voice can generate distortion.
solutions:
1. You have a "monitor" mode in the h4, just check for it, easy to find. Then you can adjust details on the h4, as you play and listen the output.
2.check the distance you are playing from the mic, be generous with that, anyhow you can move higher the gain. :)
3. Don't play directly to the mic, as the air from your instrument may generate a noise that is not a note, but simply air coming through the mic.
Monitor through computer... I'm stucked trying to make it work with any recording program in Vista, don't know how to make the system rcognize the device.So, I can't help you, and by the way, do you know how to record in Windows??
Luck bro
Posted on Jun 28, 2008
  • bostatomica Jun 28, 2008
    Got it. To record with zoom H4 in windows Vista using Audacity:
    1. Get the last software that goes inside the H4 (I forgot the name... Bios? Firmware?).
    2. Plug H4 in windows and choose "audio I/O" in the handy, off course, then choose connect.
    3. Go to Audacity - Edit - Preferences - And where it says recording device there will appear the option "H4 Audio".
    VoilĂ
    Still, Vista sound configuration is extremely base.
    Check that when you plug H4, it appears twice, as a microfone (recording devices) and as a headphone (Playing devices).
DIGITAL S METER READING TOO HIGH WHAT VR POT TO ADJUST
please follow this steps and fix it. GOD BLESS you
    • 1
Turn on all of the devices in your sound system. Turn off any auto-equalizers on your sound system to gain fullest control over frequencies. This switch might be found on the receiver or the equalizer itself.
    • 2
Play a test song on repeat. Choose a song with both extremely high and extremely low instruments so that you have a wide frequency range to listen for.
    • 3
Listen for any obvious distortions in the highs and lows of the songs. Lower the knob on your equalizer for any distorted frequencies until the distortion disappears. Try at first to find the highest setting possible without distortion.
    • 4
Adjust all frequency ranges in relation to each other to find a pleasing blend for your room, trying not to let any one frequency range dominate the others. Use the highest non-distorting settings found in Step 3 as maximum settings, but don't be afraid to lower a booming bass or a screeching flute that disrupts the overall blend of the music.
    • 5
Play a song from a different genre to test how the EQ works for different types of music. A hip hop song will have louder lows than a string quartet, for example, so make sure your bass frequencies sound crisp on both types of music.
Nov 07, 2013 | Magnum DeltaForce CB Radio
Distortion in my mic
Adjust the preamplifier level to approx. 9-12o'clock on the input trim.
Then adjust the master level to the desired output.
More about proper gain stages HERE:
http://www.homebrewaudio.com/what-are-gain-stages-in-audio-recording-and-live-sound/
Nov 06, 2013 | Shure Audio Players & Recorders
Fosgate 1500 amp settings
low pass of course set the crossover around 80Hz. Then turn the bass down to around 35% on headunit and the volume all the way up on your head unit just below distortion. slowly turn the amp gain up until you start to hear distortion, then turn it back down until it's completely gone. Then, lower the gain just a little more to make sure you keep out the distortion on all songs. From here you should be good. If the gain is still to high. The adjust to your taste. Just don't move the bass up on the headunit or the gain past your distortion point.
May 22, 2012 | Rockford Fosgate Car Audio & Video
Hot rod deluxe squeals terribly with either overdrive box or distortion box. seem fine with tremolo or chorus box.
I have had this problem at least two times and the fault was a bad hi voltage filter capacitor. With the back of the amplifier removed, it's the grey cap near the top right side. Warning: very dangerous voltage there!!
Jul 20, 2011 | Fender Hot Rod Deluxe Guitar Combo...
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Gravely distorted sound on recording
You have to download updated audio codec for your system. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
Best regards
Jan 02, 2009 | Lexicon Lambda Usb Desktop Recording...
Peavey Bass Amp TKO115s
Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
Dec 03, 2008 | Peavey EQ215FX Home Equalizer
HOW DO I TAKE THE DISTORTION OUT OF MY PC MICROPHONE THAT IS BUILT INTO MY MONITOR?
Right-click the speaker icon in the right side of the taskbar on the bottom of the screen. Select Audio properties - on the Mic section there should be a checkbox with -10db or something simular there, check that box to see if your microphone performance improves. You can also lower the slider if still less amplification is desired. Built-in mic's are of the lowest quality, and the default amplification setting can be much too high depending on your mic's sensitivity, which will cause extreme distortion. I typically only use them if my main mic fails or is unavailable.
Oct 17, 2008 | Compaq Presario 5000 PC Desktop
Midi playing is
This is specific to AcidPro.
If you doubt, check the same at your friends PC/Laptop.
You will then be sure what i told.
May 23, 2008 | Computers & Internet
Distortion with Zoom H4 as Audio I/O to computer
try using the power pack instead of batteries. Be sure to remove the batteries before using power pack, you can wreck the machine if you do not remove batteries. NEVER use the H4 on power pack while there is batteries inside.
Mar 31, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
441 people viewed this question
Top Zoom Audio Players & Recorders Experts
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
