Question about Bose SoundDock Portable Music Pack Docking Station for iPod Black (309220-1100)
Can't get the battery cover off! tried a dime, quarter, nickel, tweezers, screwdriver...wtf???
    Problem Solver:
  • 9 Answers
Could be that it doesn't fit properly and was forced into place or it may have gotten glued shut for some unknown reason( i have had some things glued shut so I know what you are thinking)
Posted on Nov 12, 2010
Testimonial: "Thanks...it wasn't a proper fit...I banged it against the table and it came off!"
Go to the facebook page for bose. http://www.facebook.com/Bose?v=app_2373072738
open a new discussion here and let them know your problem. You will get a response in 24 to 48 hrs.
Posted on Dec 13, 2010
There are 2 times as many dimes as nickels, and the value of the dimes is $1.65 more than the value of the nickels. How many nickels and dimes are there.
There are a couple of ways to figure it out, one uses algebra (ugh), the other a bit of multiplication. I choose multiplication.
Fact: Since there are twice as many dimes as nickels, we can deduce that for every two dimes there is one nickel. Thus, if we start with two dimes and one nickel, we can see that there is a difference of fifteen cents in value. Knowing that for every two dimes and one nickel we add we will increase the difference by fifteen cents, we need only divide the difference (1.65) by fifteen and that is the multiplier we need to get the proper number of coins.
165 divided by 15 = 11.
So, two dimes times 11 = 22 domes or $2.20.
One nickel times 11 = 11 nickels or $0.55.
Note there are twice as many dimes as nickels.
Note that $2.20 minus $0.55 -= $1.65.
Feb 13, 2016 | Cars & Trucks
Tip
Thanks so much for posting this tip! It's very annoying that the user guide...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Oct 26, 2008 | Kenmore Elite 45986 Front Load Washer
How many combinations of 56 cents are there?
Great question.
You could start with the number of quarters, which can be 0, 1, or 2.
If there are 0 quarters, then you only have dimes, nickels, and pennies to worry about. You can have 0 to 5 dimes. There can be 0 to 11 nickels. For pennies, there can be 1, 6, 11, 16, 21, 26, 31, 36, 41, 46, 51 and 56.
Time to work out lots of combinations!
Sounds like a summative project for a data management or statistics course or a great computer programming assignment;)
Good luck,
Paul
Find all combinations of coins when given some dollar value
Jan 16, 2016 | Office Equipment & Supplies
I want to weigh in grams but the weight of a quarter comes up 109.4 which I know a quarter should weigh 7 grms.
Try using a nickle..it weighs 5 grams
maybe this will help:
Penny Standard weight 2.5 grams
Nickel Standard weight 5.0 grams
Dime Standard weight 2.268 grams
Quarter Standard weight 5.670 grams
Oct 02, 2015 | Kutoka Interactive Didi & Ditto Preschool...
In general, how deep will a good metal detector find coins?
As long as you use your detector properly and set the sweep speeds correctly, you should be able to get to the following depths on average;
Dime/ Nickel - 4-8 inches
Quarter/Half Dollar - 6-12 inches
Dollar - 8-16 inches
Feb 21, 2013 | Retail Supplies
40 coins equaling $6.40 how many quarters and how many dimes are there.
Let x be number of quarters and y number of dimes.
  • There are 40 coins so: x+y=40 or x=40-y
  • These 40 coins equal 6.40$ and 1 quarter=0.25$ and 1 dime=0.10$: 0.25x+0.10y=6.40
  • Substitute second equation into third: 0.25*(40-y)+0.10y=6.40
  • or 10-0.25y+0.10y=6.40
  • -0.15y=6.40-10
  • -0.15y=-3.60
  • 0.15y=3.60
  • y=3.60/0.15=24
  • x=40-y=40-24=16
There are 16 quarters and 24 dimes.
Sep 27, 2011 | Office Equipment & Supplies
Learn how to change the needle in my brother xl 2600i sewing machine
If, you do not have the manual, please go to Brother.com and download one for free. Also, to change your needle without a screwdriver, use a nickel or dime. Sometimes that works better than a screwdriver and won't strip your screw head.
Jul 24, 2010 | Brother XL-2600I
VENDO PEPSI 407 soda machine
selection number 7 reads sold out but its full i have a vendo drink machine that is electronic and i push the code button to test then select number 7 vend on first button then third button to test vend and it showed an error failed .what else could i try i need some sujestions. please.
Apr 23, 2009 | Refrigerators
Bose SoundDock Portable Music Pack Docking Station for iPod Black (309220-1100) Logo
253 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
