Question about Intel Panasonice DVD Rom Drive Internal DVD Drive
The dvd player on my Panasonic NV-VP31 combo does not work. The only message at play is "close". I have tried using a cleaner disk without any further result. Earlier the dots appeared on the tv screen and then repeated flashes occurred. Any help appreciated.
Blu ray player will not play any disk. Player stays in "load" mode. Open an close controls do not work. Have unplugged and replug. Player tries to load even without a disk in the player. Wireless...
Try to clean your player with a lens cleaner. Insert the cleaner to the player for 3 minutes or until cleaning process is done. If you don't have lens cleaner use a cotton buds with alcohol to clean the lens. Open the cover of the player and dismantle the upper assembly that protects the player. Using the cotton buds clean it with extra care.
Nov 29, 2010 | Samsung BD-P3600 Blu-Ray Player
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Unlock code for Panasonic NV-VP31 DVD Player
HELLO
I have one of these units and you CANNOT hack the DVD section by the remote alone. However, I got a special remote at
www.genuinecopies.tv
It will only cost you a few pounds and the instructions how to use it are included (and they DO work). You'll then be able to watch DVD's from anywhere in the world!
ENJOY! (:-)
Oct 05, 2009 | Panasonic Televison & Video
Crack Code
HELLO
I have just posted the solution, but just to say that if you go to www.genuinecopies.tv you can a remote that will hack the DVD section - I got one for mine - works a treat!
ENJOY (:-)
Oct 05, 2009 | Televison & Video
No Free Region Code.
HELLO!
You'll find that quite a number of Panasonic units cannot be hacked via the remote control alone and usually the unit is LOCKED to a certain region. Have a look on this website www.genuinecopies.tv
They sell remotes to unlock the machine and they work! I got one for my NV-VP31 unit.
I wish you luck your problem!
Sep 01, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Panasonic DVD playerS35 error H 07
HELLO
H07 is the fault code for the disc motor and here is what you need to do to remedy it.
The cover of the player will have to be removed to do this. Locate the the actual motor shaft and where it goes into the motor itself, put a little drop of light oil or WD40. Let it soak in for a little while and try it again. I'm sure you will find it now works.
I had this problem on Panasonic NV-VP31 DVD/VCR unit and I have had no more trouble since!
HOPE THIS HAS HELPED - ENJOY!
Aug 18, 2007 | FEC RKMV5 Custom Rackmount Kit for JVC...
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Intel Panasonice DVD Rom Drive Internal DVD Drive Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
